swap from mechanical to electronic speedo?
Old Jan 16, 2010 | 05:35 PM
rotccapt's Avatar
hi all is it possible/ cost effective to swap from a mechanical cable driven speedo to an electronic speedo. i have an 86 toyota pick up
Old Jan 16, 2010 | 07:12 PM
laskt9's Avatar
im interested in the answer too
Old Jan 17, 2010 | 09:24 AM
tacho75's Avatar
me 2 ..........
Old Jan 17, 2010 | 09:57 AM
hiltu's Avatar
some GPS units now display speed. I may go that route if/when i get gears
Old Jan 17, 2010 | 10:27 AM
DeathCougar's Avatar
They did not start electrical speedos until 1992 so unless you want to rewire your entire truck, PLUS deal with the headache of parts that are MORE expensive, i wouldn't do it.
That $70 cable is much cheaper than the $240 speed sensor.
Old Jan 17, 2010 | 11:38 AM
airkewld4life's Avatar
It can be done without re-wiring you entire vehicle
Google Hall effect speedometer sender. There are multiple options but I chose to buy the Autometer one. I did this exact thing to one of my Bugs. I wanted all Autometer Cobalt series gauges and unfortunately, they did not make a mechanical Cobalt speedo. So, I started doing some research and came across the Hall effect senders. Most of the senders say they are for Ford or Chrysler/GM but the cable from my Bug threaded right on. Here is a basic install sheet from Autometer
http://www.autometer.com/productPDF/1168.pdf
Good luck
Old Jan 17, 2010 | 11:53 AM
Autometer being aftermarket gauges.
I should have clarified, i was talking OEM parts only.
Old Jan 17, 2010 | 11:59 AM
Wink
Touche.
OP should clarify as well
Old Jan 17, 2010 | 04:44 PM
rotccapt's Avatar
oem after market does not really mater. i finaly got my mecanical settup working again but i am still looking at ideas. i found a unit on merlin crawler that supposedly will work too.
jasonty
41
Dec 23, 2018 01:00 PM
mskalmus
May 28, 2017 07:51 AM
keithporter83
Jul 24, 2015 07:37 AM
msane99
Jul 11, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
