94 3.0 overheating?
Old Sep 2, 2010 | 05:11 PM
jbridered's Avatar
94 3.0 overheating?
My 94 v6 4x4 is overheating while pulling a 13ft scamp (light trailer). I removed the Thermostat so that isnt the problem. After the t-stat removed shouldnt i see good flow when the radiator cap is removed? I dont see good flow which leaves me to believe there is a blockage somewhere. My radiator was rodded out about a year ago. Any suggestions?
Old Sep 2, 2010 | 05:56 PM
iselloil's Avatar
Fan clutch.
Old Sep 2, 2010 | 07:27 PM
jbridered's Avatar
So even though the fan is turning fine? Shouldnt i see flow in the radiator since i removed the thermostat?
Old Sep 2, 2010 | 09:26 PM
pruney81's Avatar
It could be the water pump...since you're not seeing any flow in the radiator
Old Sep 3, 2010 | 05:38 AM
iselloil's Avatar
Got to see flow.
Old Sep 4, 2010 | 11:24 AM
jbridered's Avatar
Waterpump is not leaking. I am gonna do a real good flush and see if it makes a difference.
Old Sep 4, 2010 | 11:30 AM
camo31_10.50's Avatar
flush it first.
it could be the water pump...just cuz the water pump isn't leaking...doesn't mean it's pumping
Old Sep 8, 2010 | 07:09 PM
jbridered's Avatar
I flushed and noticed flow in the rad. I took it to town and drove it for about an hour after the flush and it started to get close to the red when i was about 5 minutes from home. I lifted the hood and found the rad hose from the motor had two holes in it. I never noticed this before so i think its just old and couldnt stand another really hot one. I am thinking my rad is the problem. Any advice on whether to tell if its the waterpump or rad?
Old Sep 8, 2010 | 07:26 PM
91_TOYOTA_4x4's Avatar
my 3vze gets hot if it sits for more than 5 mins, other than that its right where it should be. im thinking my water pump is done. sounds like you could have a block in the system, but i would do a water pump. there isnt much of a way to tell if its bad so just take it off and replace it. i think they are like 130 bucks and you get a new timing belt too
Old Sep 10, 2010 | 04:27 AM
TNRabbit's Avatar
It's the radiator. You can get a new all metal radiator from CSF online for about $200.00.
Check my thread: https://www.yotatech.com/forums/f116...d-pics-193478/
Old Sep 10, 2010 | 08:02 AM
jbridered's Avatar
rad rod
Can you rod the radiator more than once? Last time they did a good job.
Old Sep 10, 2010 | 02:22 PM
starrjewel's Avatar
I am actually in the process of changing out the water pump in my 93 Toyota T100 4WD 3.0 I started with the radiator because of the obvious 5" fine crack in the very top. After replacing the radiator, I filled with coolant and hoped there weren't other components causing the overheating.
Unfortunately, it overheated again with the new radiator. I drained coolant and replaced thermostat. I let it run at normal temp for about 10 min with no signs of increase in temp.
I drove it to work that night and everything seemed fine. I came out 3 hours later to do a bank run and noticed my precious coolant all over the ground and the water pump dripping underneath.
I am now opening up the timing cover and trying to replace the water pump. I haven't done this task before so its definitely a learning experience! Since I have to take timing belt off and be so careful with the positions, I'm replacing it as well as the timing tensioner and idler. I bought new spark plugs to swap out. I am hoping that this job will make my yota run ever so beautiful! It has 150K on it and needed a little internal TLC!
Many have told me I don't have to change belt, tensioner or idler but its never been done. Sure as I try to put it all back together that's when it would fail on me and destroy my timing and everything else that is kept in line by it.
LotOMiles
Sep 14, 2015 11:45 PM
sanctfy
Sep 13, 2015 06:33 PM
noahstancik
Sep 10, 2015 10:47 AM
FJtoyman
Sep 8, 2015 04:47 AM
seab1209
Sep 3, 2015 05:41 PM
