Tranny Question
Old Sep 7, 2010 | 04:24 PM
Gordo's Avatar
Tranny Question
I am need of a new transmission (5spd) 88 4runner. I went to the Marlin site to get a quote and to my surprize the site showed that the W56 for 88 Toyota is a AX15. This transmission is used on Jeeps with 6 cly engines. Does anyone know if a AX15 from Jeep will fit the 22RE engine? Seems that I can get a used AX15 for pretty cheap.
Old Sep 7, 2010 | 04:29 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
The AX should be the R-150...
Then you'll have the trouble of the bell housing and tail shaft for the TC you need to use...
http://www.novak-adapt.com/knowledge/ax15.htm
Here's the AX5. That's the one you're thinking about...
http://www.novak-adapt.com/knowledge/ax5.htm
Old Sep 7, 2010 | 05:27 PM
Gordo's Avatar
Thanks I knew it was to good to be true.
Dieselmann
Feb 19, 2019 02:57 AM
Tonetrk
Aug 6, 2015 10:06 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
