94 22re wont start.
Old Aug 22, 2010 | 09:20 AM
NSyotowner's Avatar
Question 94 22re wont start.
My toyota 22re died last week and had it towed home. I can't get a compression reading from any cylinder and it's a "weaker" cranking sound for lack of a better word. Changed timing chain components and it was definately needed. Guards were eaten up and over 50% of them were in the oil pan as well as some metal from timing cover. Cleaned everything out, new gaskets and rings everywhere. I'm getting fuel and spark. No oil in coolant, no coolant in oil. i'm rather novice with engines as this was as far into one as i've been. After everything was put back on, same problem. Strange "weaker" or maybe "lighter" cranking sound, no compression. What am I missing here? I'm as confused as everyone else i've asked is. Bent valve? Blown head w/no symptoms? Any help is appreciated.
Old Aug 22, 2010 | 11:01 AM
thook's Avatar
You said it "died" last week. What was the nature of the circumstance? IOW's, how did it die? What happened?
Old Aug 22, 2010 | 12:16 PM
NSyotowner's Avatar
Sorry thook. Was backing into spot at work, went from reverse to drive after backing up too far. Cut wheel hard to straighten out and when i released brake to inch forward, engine cut out.
Old Aug 22, 2010 | 12:21 PM
NSyotowner's Avatar
The drive to work is 20 min and about 10 miles of it it highway going about 65mph. If that figures in.
SubiKing
Aug 21, 2021 03:57 AM
Doug4320
Mar 24, 2018 10:11 PM
Iceman4193
Aug 28, 2015 08:43 PM
redneck17
Aug 12, 2015 08:15 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
