clutch chatter with no slippage and transmission mount
hello
i have been having clutch chatter for for about 1/2 a yr now
i have a 1990 22re
i just changed the transmission mount.
wow what a differance..
its only been 2 days but there is a big differance..i have very little to no clutch chatter anymore..
the mount was sooo bad its was 20 yrs old
with the new mount the transmission sits up about 1/2 to 1 inch higher..
so if you got clutch chatter check that 1st.
i have a 1990 22re
good post, my shifter shakes alot if not under load, but the transmission and tcase mount looks good, i dont think its a "problem" but if theres a simple solution ill fix it lol
Here it is.
https://www.yotatech.com/forums/f116...-mount-219443/
Guess it was a week ago...time flies!
Or the clutch was replaced with out getting the flywheel resurfaced? Mine did that a bit where it would chatter after taking off and grab just fine when fully engaged.
Here it is.
Shaun Crystal Gomban
07-30-2015 10:13 PM
HookahRoo
07-20-2015 07:06 PM
