Bad Converter?
Old Aug 29, 2010 | 04:30 PM
jagermeister's Avatar
Bad Converter?
I have a 94 4runner with an A340H tranny, I was driving down 95 yesterday everything going fine then all the sudden she starts down sifting all the way and lose power pull off stop and she shuts off and is overheated. let her cool off starts up and revs up fine but when in gear moves but has no power, kinda like its slipping. Im thinking bad converter or converter cluctch is starting to go. I know if ur converter is completely bad you truck wont move at all and that y im thinking converter clutch? any thoughts?
Old Aug 29, 2010 | 05:03 PM
or maybe the oil pump in the tranns?
Old Aug 29, 2010 | 06:04 PM
881stGenRunner's Avatar
Bad day dude, sorry hear youre having problems with your tranny. I would pull up an FSM and start looking at the troubleshooting sections.
Best advice i can give, 5 speed swap it. It is VERY worth it.
Old Aug 29, 2010 | 07:31 PM
haha ya i should had done a 5 speed swap when I REPLACED this tranny a month or two ago, it came from a junk yard with 80,000 miles on it and i got it for a good deal my last one reverse went out on it and i think this one just needs a new converter but idk, so im trying to get a lil info but ya i got a FSM for the A340H tranny and it showed me a way to test the converter clutch but u need this stupid tool and i don't have one but does anyone know where i could get one?
Old Aug 30, 2010 | 11:41 AM
does anyone else think it might the torque converter/ converter clutch? and another reason?
Old Aug 30, 2010 | 12:09 PM
Ya i made the mistake of putting another auto tranny in mine too. Got it right the 3rd time though haha. I see your problem, its not always easy to do the tests in the way they do. Cant you do a converter stall test to see if your TC is going out? check for that test in the fsm, maybe that'll do it.
Old Aug 30, 2010 | 02:27 PM
Alright ya i see the stall test and where it saying if rpm is lower than specified value converter clutch my be faulty. is the stall test and converter stall test the same? and also in the test it says Stall speed: 2,850 f 150 RPM, what does this mean excatly?
Old Aug 30, 2010 | 02:47 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Have you perused?
http://www.pirate4x4.com/forum/showthread.php?t=587521
Does your OD/ off light work?
" When the computer detects a mechanical or speed sensor problem, it goes into a "limp home" or failsafe mode. It will defaut into 3rd gear (direct drive) and the OD light will flash."
Old Aug 30, 2010 | 03:12 PM
yes it does work and it doesn't flash like in the quote u posted and it shifts fine, it doesnt start off in 3rd gear
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
daddio
Aug 9, 2015 07:17 PM
129Creepin
Aug 5, 2015 10:12 PM
Esibnitsud
Jul 30, 2015 08:19 PM
crashburnoveride
Jul 10, 2015 06:39 AM
