shift problems.
Old Sep 7, 2010 | 09:28 AM
ricerocket2's Avatar
shift problems.
have a 1990 totyota 4x4 automatic tranny.. it will not shift out of park unless the manual shift lock override button is pressed! any help on what the problem may be? could it the stop light swith, or the shifter solenoid, or neutral override switch?
Old Sep 7, 2010 | 12:24 PM
greatskiiiier's Avatar
if it shifts out of park good with the shift lock override button pressed then whats the problem?
Old Sep 7, 2010 | 12:44 PM
normally u press the brake pull the handle down but when u press the brake the shift button wont press and shift the only way u can get the truck to shift in gear is to press the lil black override button on the bottom of the shifter console then push the botton on the shift handle and pull down...
punks_is_4x4
Feb 26, 2016 04:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
Flightguy
Oct 2, 2015 05:34 PM
kbpickens
Oct 2, 2015 03:37 PM
creecher10
Sep 30, 2015 03:27 PM
