Transmission- What is this?
Old Aug 23, 2010 | 06:26 PM
gbwsaw28's Avatar
I don't know which transmission I have. Its a 88 4runner 5 spd 4WD
Is something wrong here? What did this sensor connect to?
Also, I have one hanging plastic connector and one that is plugged in. That normal?
thanks
Old Aug 23, 2010 | 06:49 PM
malteserunner's Avatar
It couldn't be that obvious....or, could it? Maybe the wire in picture 1 goes to the plug in picture 2??
Old Aug 23, 2010 | 06:50 PM
MudHippy's Avatar
O.k., I'm not too familiar with that transmission/transfer case combo, but I believe that the one shown in the first pic there should be the 4wd indicator switch. It triggers the "4WD" light on the dash when you engage the 4wd.
You'll have to gimme a sec' on the other one.
Whoa! Hold up! You know what? You may have a point there!
Old Aug 23, 2010 | 06:54 PM
The first pic is the 4wd indicator switch, and the second pic is the reverse light switch.
Old Aug 23, 2010 | 07:08 PM
gbwsaw28's Avatar
so should the hanging plastic connector be connected to the 4wd indicator switch on the other side?
Old Aug 23, 2010 | 07:10 PM
Affirmative.
Old Aug 23, 2010 | 07:14 PM
gbwsaw28's Avatar
Thank you. I figured the electrical wire just wasn't long enough to reach that side.So simple. Again, Thanks
Old Aug 23, 2010 | 07:17 PM
It goes over the top of the tranny.
Old Aug 23, 2010 | 07:45 PM
BrianJE's Avatar
Hell! Thanks guys! You solved my back up light failure. Thanks A lot!
Burly
Oct 10, 2014 04:38 AM
Jthod
Jul 7, 2014 06:18 PM
FUNrunner87
All Other Toyota Swaps
Jul 8, 2013 05:54 PM
VolVette
Aug 25, 2012 12:36 PM
