93 22re problems........HELP.
Old Oct 25, 2012 | 03:39 PM
bcleapor's Avatar
ok so my buddy has a 93 with the 22re efi. it has been giving us problems with no power. sometimes it will run good enough to pull up a hill. most times it will just all the sudden loose power, rough idle, pours black smoke and actually throws flames out the exhaust some times. we were thinking timing is off a little. but im thinking he is loosing compression somewhere. any ideas. and if you need more info, i can try and articulate a little more.
Old Oct 25, 2012 | 04:01 PM
brianh699's Avatar
Black smoke sounds like unburned fuel, ignition system would be my first check.
Old Oct 25, 2012 | 04:06 PM
bcleapor's Avatar
we have replaced the dist. cap and rotor button. coil, plugs, wires. so i dont know what else in the ignition department to check.
Old Oct 25, 2012 | 04:22 PM
brianh699's Avatar
Have you checked for trouble codes in the ecu? Is the ignition timing correct?
Old Oct 25, 2012 | 04:45 PM
bcleapor's Avatar
thats a good question. i know he replaced the ecu recently. so that might be a possiblity. ill get back to ya later on that one. thanks.
Old Nov 8, 2012 | 02:26 PM
bcleapor's Avatar
ok so we have replaced the fuel pressure regulator and fixed the timing but it still runs like hell. its still pumping black smoke, and now it has started throwing flames from the exhaust.
HELP
Old Nov 8, 2012 | 02:31 PM
smracing's Avatar
TPS is a good bet, followed by the AFM.
Old Nov 8, 2012 | 02:49 PM
bcleapor's Avatar
sorry, im not up to par on the accronyms. Im assuming TPS is throttle position sensor and what is AFM.
Old Nov 8, 2012 | 04:20 PM
brianh699's Avatar
Air flow meter, it's the silver unit on top of the air filter housing.
Old Nov 9, 2012 | 09:23 AM
bcleapor's Avatar
Ok, as far as the Air Flow Meter. we replaced that last earlier this year. so i dont know.
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
