Hex bolt for manifold bolt - ok?
Old Nov 2, 2012 | 10:02 AM
Josh_Br's Avatar
I have a 1990 Toyota pickup. The engine block and head are from a 1994. One exhaust manifold stud is missing (the front most bottom stud). Can I just use a hardened bolt with the same thread pattern, so long as it is the proper length?
Also, on the outside of the exhause manifold, part way down, there are three holes for bolts. One of these holes does have a bolt in it, but the other two do not. They appear to be places to attach brackets, etc, to. Is the absence of these two bolts hurting anything?
Thanks,
Josh
Old Nov 2, 2012 | 10:59 AM
Replicant's Avatar
I used regular bolts for mine and havent had a problem. I just put lock washers on them.
Old Nov 2, 2012 | 11:34 AM
SPARKS89's Avatar
Those three bolt holes on the outside of the exhaust manifold are for bolting the heat shield to it.
Old Nov 2, 2012 | 11:36 AM
Josh_Br's Avatar
Awesome, thank you both very much.
RobotMoose
Sep 2, 2015 05:53 AM
Dakotaneu
Aug 15, 2015 07:24 AM
accuracy
Aug 6, 2015 12:32 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
