MPG on a trip
Old Oct 28, 2012 | 07:50 PM
toy_baja_13's Avatar
MPG on a trip
Just did 600 miles in my 1992 pickup 4x4 single cab 5speed 22re and got an average of 15.5mpg going through mountains and the high plains (Las Cruces NM to Clovis NM and back). This was with my RM250 dirt bike, gear, loading ramp, and weekend bag in the bed. Motor is stock on a fresh rebuild (95,027miles on chassis, and 4,345miles on motor) with .30 pistons. Was very pleased since this was my first trip with this truck. I bought it back in August. Like i said motor is all stock, 31 in A/T tires, and 4.11 gears. Only gripe I have is it is VERY lacking in power when climbing uphill! Went from 5th gear at 70mph to 45mph in 3rd gear. Any suggestions as how to gain more power/lose less mph without sacrificing to much on the mpg side? I know with performance you sacrifice mpg but want to be able to meet somewhere in the middle.
Old Oct 28, 2012 | 08:02 PM
thebeeler's Avatar
I have the same problem truck cruise's great but try point it up any kind of hill and you end in 3rd gear revving it up or 4th gear bogging it down. All the bolt on's in the world will only give you like a 4mph gain if your lucky. Have to go internal to see any kind of real results. Or a motor swap like many people will tell you.
Old Oct 28, 2012 | 08:06 PM
that was about 250 total miles of my trip...lol. id love to motor swap it but i need to keep 4wd
Old Oct 28, 2012 | 08:20 PM
missyota84's Avatar
why couldnt you keep 4wd with motor swap?
Old Oct 28, 2012 | 08:28 PM
toyota4x4907's Avatar
Seems that most people who get an ENGNBLDR performance head and cam see an increase in power and mpg... Also, either regearing for larger tires or going back to stock size tire will help.
15.5 is interesting to me. I like to camp in the summer; my friends and I usually take my 4Runner ('95, 22re 5spd) and I get 18-22mpg with 3-4 of us, our camping gear- whether its in the cargo area or on the roof rack. There are quite a few large mountain passes wherever I go camping, so its pretty comparable to your trip. But I have a lift, 33x12.5 tires and stock 4.10 gears....
Old Oct 28, 2012 | 08:32 PM
which motor retains 4wd? and i will look into the head and cam idea.
Old Oct 28, 2012 | 08:34 PM
thebeeler's Avatar
Any motor swap can be made to retain 4x4, some just take more money than others.
Old Oct 28, 2012 | 08:46 PM
well im new to toyota's... what is a common swap?
Old Oct 28, 2012 | 08:48 PM
runs-on-4's Avatar
if youre getting 15 mpg with a 22re and 31s on a trip theres something that isnt right, your motor should be way more effcient. my 3.0 gets better than that on trips on 35s. with 410s.
do your basic tune up maybe replace your o2 sensor somtimes those things kill mpg.
best motor swap for the money and time probably 5vze
what did you mean by retain 4wd?
Old Oct 28, 2012 | 09:36 PM
nieb15's Avatar
Most common engine swap seems to be to the 3.4L or 5VZ-FE.
Old Oct 28, 2012 | 09:44 PM
iliketoyota's Avatar
replace your fuel filter, oxygen sensor, plugs, wires, and maybe cap and rotor.
Old Oct 29, 2012 | 06:20 AM
Resto-noob's Avatar
31s-especially on steel wheels-aren't helping. 225s or 235s would make a pretty big difference, on aluminum rims even more. I always ran smaller tires in the winter, and the truck got much peppier as a result.
Old Oct 29, 2012 | 07:24 AM
xylicon's Avatar
Agreed, you might need to do some tinkering.
I pulled up a 7% grade with two dirt bikes and a load of gear in the bed of my 88 4X4 22re stock gears & tires going 55MPH in 3rd ~3600RPM. I could have gone faster but I didn't want to wind it out too much.
Old Oct 29, 2012 | 07:38 AM
Spazzcdnm's Avatar
Its a 22 RE. Thats like having 4 angry squirrels pull you up a hill. I usually try and give mine a few energy drinks before a trip.. Seems to help...
In all seriousness though. I just deal with mine. There is no replacement for displacement. I cant think of anything within a reasonable budget other than dropping tire size to help with that. Otherwise you are looking at either re-gearing or a motor swap (I am looking into a 7mgte personally).
Old Oct 29, 2012 | 10:44 AM
You could get some 4:88's out of a v6 auto.
Old Oct 29, 2012 | 03:08 PM
thanks to everyone for their input! Seems I may like this forum after all...lol I am not as worried about the mpg as much as being able to tow stuff. I travel alot (personal and business) and just want a little bit more spunk... I am used to fast low cars. sounds like the goal is 4.88's, intake manifold, bigger throttle body, intake, cam, head work, header, and exhaust.
Old Oct 29, 2012 | 03:21 PM
donomite49's Avatar
save your money.
3.4 v6 swap, or
2.7 4cyl swap...
http://toyonlyswaps.com/
Old Oct 29, 2012 | 03:38 PM
Good link, very informative, but if im going to spend that kinda cash for a stock motor I will just find a complete truck and drive it... seems to be about a $6000 swap and for that i can go to LCE engineering and buy a stage 3 long block and all need parts and it be a brand new motor
Old Oct 29, 2012 | 04:11 PM
donomite49's Avatar
a stock motor that has 150 hp 4cyl.
or 190 hp v6.
with supercharging you can add 100 hp to that plus lots more torque.
Old Oct 29, 2012 | 04:15 PM
donomite49's Avatar
i just got back from my first trip with my 3.4.
hauling two bikes trailer etc (about 1000 pounds) i got 19 mpg going 75-85 up every hill.
