funky name for grease
Old Jan 20, 2009 | 08:48 PM
machine23's Avatar
im preparing to replace my cv's and i noticed it calls for molibdenum disulphide lithium base grease. is this necessary? cant i just use a regular lithium grease? or does it have to be the special toyota stuff?
some pointers would be greatly appreciated!
Old Jan 20, 2009 | 08:52 PM
4Crawler's Avatar
Should be able to find that type of grease at most auto parts stores. They may even carry a special CV joint grease. I usually find that in the Sta Lube brand. CV joints need a special type of grease.
Old Jan 20, 2009 | 08:58 PM
Matt16's Avatar
Molybdenum disulphide is commonly referred to as "moly" grease or lube, available at just about any auto parts store. Its really thick and sticky and does really well under pressure. In fall/winter/spring, you could take a yogurt container of moly, press it to the roof and it would probably still be there in the shape of the yogurt container in the morning!
Old Jan 20, 2009 | 09:07 PM
abecedarian's Avatar
(Graphic content follows. Parental discresion is advised... or at least some good degreaser....)
CV joint grease makes peanut butter melted into carpet look thin. Ever have one of those toilet visits where you keep wiping, and wiping, and wiping... and there's still something to clean up- the more you clean, the more you wipe? CV grease is worse than that. I heard a comparison once about trying to clean peanut butter from shag carpet with kleenex tissue. Does that help?
Do not go cheap. Get what is recommended.
Old Jan 20, 2009 | 09:19 PM
874runnersr5's Avatar
lol abe,
yeah, cv grease is a mess. When i did my cv's, i destroyed one of the boots.. wow never again.
Old Jan 20, 2009 | 09:22 PM
TacoNut's Avatar
Man, I didn't need that picture in my head!
Old Jan 20, 2009 | 10:07 PM
aviator's Avatar
Yeah thanks a lot abe... but your description is apt I'll give you that...
Old Jan 20, 2009 | 10:19 PM
904runner-ohio's Avatar
Molle-B is some good stuff. I was a CH-53E airframer in the Marines and we used the stuff on our helos. It is ungodly messy, but its worth the clean-up.
Old Jan 20, 2009 | 10:47 PM
Matt16's Avatar
I don't think it was that messy, but I squeezed the tube of CV grease that came with the boots directly into the boots.
Just checking that you mean on the splined outer end of the CV shaft as opposed to inside the boots- you said you were replacing them instead of repairing them. I do believe moly is specified for use on the splines as well.
Old Jan 20, 2009 | 10:51 PM
86tuning's Avatar
cvs require cv grease, which is black. lithium grease is no good, use the right stuff. any parts store will have cv grease in stock.
Old Jan 21, 2009 | 06:34 AM
Astralplane's Avatar
Are you replacing just the boots or the whole Cv's?
The boot kit from Toyota has one type of grease for the inside boot and another for the outside boot.
OEM boot kit is very nice.
Old Jan 21, 2009 | 09:33 AM
Matt16's Avatar
But very expensive. It costs $80 here while the Beck Arnley costs $17 per side.
Old Jan 21, 2009 | 09:47 AM
runethechamp's Avatar
I would have to check to be sure, but I seem to remember I paid $25 or $30 or so for my kit when I bought it at the dealer a couple of years back.
Old Jan 21, 2009 | 10:17 AM
Matt16's Avatar
Triple checked. That simply is the Canadian price, and they usually reflect the American prices, but perhaps this price doesn't.
Old Jan 21, 2009 | 11:19 AM
MSRP is $37, and you can get it for $26.69 at toyotapartsales.com. Too bad it's that much more expensive in Canadia :
Old Jan 21, 2009 | 11:24 AM
ozziesironmanoffroad's Avatar
so its aboot 35 bucks for ya'll, huh?
Old Jan 22, 2009 | 06:02 AM
I paid $33.84 Aug. 2007
Part# 04428-35010
Old Jan 22, 2009 | 09:23 AM
Matt16's Avatar
I believe that was $80/side actually. Can't use "y'all" anymore, the village idiot is back in Midlands, Texas.
Old Jan 22, 2009 | 12:10 PM
Cyclopsblown34's Avatar
Just so youins know, the molybdenum is an extreme pressure (EP) additive that is necessary in such applications, I wouldn't skimp on it. The CV joints operate under a lot of pressure and need the added lubricity.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
puddlepirate
Jul 30, 2016 06:29 PM
puddlepirate
Sep 29, 2015 08:02 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
