Broken valve cover stud
Old Jan 24, 2009 | 02:00 PM
nicko3632's Avatar
I broke a valve cover stud today while adjusting my rocker arms. What is the corect size replacement stud? What is the easiest way to remove the broken stud? The stud broke off about 1" above the head.
Sorry im a little new to the yota thing, been a GM guy all my life but I finally decided I wanted something that would be more reliable for a DD.. lol.
Oh, the truck is a 90 2wd pickup with a 22r.
Old Jan 24, 2009 | 05:11 PM
scope103's Avatar
I'm 99% sure they are 8mm-1.25, but the way I would tell is take one out, and take it to the hdwe store with me. Actually, I would take them all out, lift off the valve cover, and remove the broken one CAREFULLY with a pair of vise grips. Using an "easy out" when you have reasonable access would be madness.
Old Jan 24, 2009 | 06:29 PM
abecedarian's Avatar
with all due respect...
how do you break a valve cover stud?
Old Jan 24, 2009 | 06:50 PM
my-4x4's Avatar
Curious myself...(for future motor work)
Old Jan 24, 2009 | 06:58 PM
considering the nut tightens down on a rubber washer that only has to show 'some' sign of compression / deformation... I am at a loss to describe how one of those studs gets broken.
Old Jan 24, 2009 | 07:09 PM
my-4x4's Avatar
He could've possibly did what I had done, used Air impact wrench, except I broke a stud while replacing ball joints. TIP: DO NOT USE IMPACT WRENCH FOR TIGHTENING!
Old Jan 24, 2009 | 07:37 PM
85excab's Avatar
no, no one can be dumb enough to use an impact to tighten down an aluminum valve cover.
Old Jan 24, 2009 | 08:24 PM
who said impact?
Could have been an air ratchet.
Old Jan 24, 2009 | 08:35 PM
drew303's Avatar
Maybe he just likes it tight...dont you?
didnt say how it broke, could of snapped (ie crossthread) ?
Old Jan 24, 2009 | 11:47 PM
my-4x4's Avatar
I do like my chassie to have tight parts....
But anyways maybe he fixed problem he never responded...
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
