what do I need to remove to weld?
Old Jan 18, 2009 | 01:40 PM
xzyragon's Avatar
Well, im gonna weld a piece of my frame back onto the car, and I know i need to remove stuff.
What exactly do I need to remove?
Alternator, battery?
thanks
Old Jan 18, 2009 | 01:43 PM
swapped89's Avatar
i welded on my frame and didnt disconnect anything, but to be safe you could just disconnect the battery cables. i think if you have a winch you need to disconnect it. i heard you can fry them if you weld with them all hooked up, just my opinion
Old Jan 18, 2009 | 01:44 PM
xzyragon's Avatar
i heard from somewhere u need to disconnect the alternator... i don't really feel like it so i just wanna make sure.
The battery is way easy to disconnect.
What about my circuits?
Old Jan 18, 2009 | 02:28 PM
Tubbyfatty's Avatar
Disconnect the battery and make sure you put the ground clamp really close to what you are welding so that the ciruit is really small.
Old Jan 18, 2009 | 06:26 PM
idanity's Avatar
if you want to be anal, remove
battery
fuses
unplug relays
alt
starter...
im no welder, but i know its a pita to track down electrical stuff.
Old Jan 18, 2009 | 06:49 PM
desconhecido's Avatar
The most important thing to remember is not to ground on the chassis and weld on the door.
Old Jan 18, 2009 | 07:33 PM
T-1000's Avatar
I just got done welding on the body today, I had a door open and watched the lights when I threw an arc just to see what happened.
The answer (not surprisingly) is nothing. And it started up and drove just fine, radio worked too.
Just make sure you put the ground close to where the arc will be (and on the same piece of metal) and you should be fine.
Old Jan 18, 2009 | 07:57 PM
874runnersr5's Avatar
Just disconnect the postive on your battery.
Old Jan 18, 2009 | 08:00 PM
abecedarian's Avatar
everyone just covered most everyting possible-
place the ground electrode as close to the weld as possible
disconnect the battery (at least the positive, and keep it insulated from the rest of the vehicle)
you should be fine.
Old Jan 18, 2009 | 08:02 PM
86Toyrunna's Avatar
disconnect both terminals on the batt.... and ground close to what ur welding.. some newer vehicles may have more they want disconected.. might possibly be in the service manual or under the hood.. never really looked before.
nvdesertrunner
May 11, 2020 08:18 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
shisha1999
Aug 14, 2015 01:33 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
