what is this?
Old Jan 25, 2009 | 01:20 PM
91 yota's Avatar
what is this?
91 22re. on the maf it looks like some kind of adjustment screw. what is that for? thanks
Old Jan 25, 2009 | 01:29 PM
corax's Avatar
pics?
it might be the air bypass screw which controls air flow through a passage that goes around the flapper door - adjustment for idle mixture. Personally, I wouldn't mess with it, won't gain you anything.
Old Jan 25, 2009 | 01:36 PM
91 yota's Avatar
i bought the truck with the motor out of it. and i can tell someone has messed with this screw.
the plugs are starting to worry me as they are very white. with crusty stuff all over them. like its lean.
Old Jan 25, 2009 | 02:27 PM
iamsuperbleeder's Avatar
I believe that's suppose to have a metal cap over it; you wont see the screw unless someone has fiddled with it in the past
couldn't tell ya what it's for though
maybe adjust the amount of air that can go through the bypass passage in the AFM?
Old Jan 25, 2009 | 04:37 PM
91 yota's Avatar
on another note, does detonation sound like a loose valve? it sounds like i got one but there are all adjusted right.
Old Jan 25, 2009 | 04:43 PM
abecedarian's Avatar
umm... idle mixture adjustment- let's the Toyata engineers and parts manufacturers fine tune the mixture "between" the teeth on the gear inside the AFM.
but don't tell anyone I told you that.
and for the record, it only affects the mixture at idle. above idle, there's too much air flowing through the AFM for that adjustment to be significant. Off-idle, the ECU is looking at the O2 sensor for feedback and would override any 'tweak' to that screw anyways.
Old Jan 25, 2009 | 04:47 PM
I thought that's the flat-head adjustment screw on the TB? or do they kinda serve that same pupose...
Old Jan 25, 2009 | 04:48 PM
idle "fuel" (air/fuel ratio) mixture, not idle "speed".
Old Jan 25, 2009 | 04:49 PM
oh, duh, ok, nevermind
wow... total brain fart...
it's late, I'm tired, sorry, lol
Old Jan 25, 2009 | 04:50 PM
it's late here too... like almost 9:00 pm.
and have to ask: do brain farts smell?
Old Jan 25, 2009 | 04:54 PM
91 yota's Avatar
ok so what does detonation sound like? it only makes the noise while it cruisin. not on accel or decel. it don't sound like the noise is in the timing chain area. sounds like its in back of motor. and it has 180pounds of compression on all cylinders.
Old Jan 25, 2009 | 04:56 PM
their horible...
just don't try to light them on fire; you'll get the opposite of a brain freeze
Yeah, almost 9pm here as well... normally wouldn't be late for me, but I have to get up at 2:30 and make a 3 hour trip down south for business; my first real "business trip" with the company... I feel like a high roller now their issuing me a laptop when I get down there, putting me in a company truck to make the trip, and a hotel suit to myself for 2 days all because the head honcho at our southern Florida branch slacked off, turned the place into hell, and now the head honcho over all of Florida and I get to go down there and straighten the place up
have you ruled out an exhaust leak?
Old Jan 25, 2009 | 04:57 PM
91 yota's Avatar
abe you in ohio now? i got a good buddy in akron.
Old Jan 25, 2009 | 05:07 PM
detonation sounds somewhat like a few BB's being shaken in a tin can (if you can imagine), random high-pitched 'tinks'.
You can also get some noise that sounds similar to pinging or an exhaust leak through the PAIR system. My wife just replaced the converter on her 91 and the noise she thought was an exhaust leak went away, presumably because of an increase in backpressure changing how the air flowed through the PAIR manifold.
I'm in Mason, working at the WLW radio facility.
Old Jan 25, 2009 | 05:18 PM
91 yota's Avatar
ha ha see i kinda thought this was a small exhaust leak. but today i checked all the bolts and they were tight.
