Water Pump Bolt/Nuts
Old Jan 27, 2020 | 11:53 AM
Raiderfan0224's Avatar
So I swapped my water pump out on my 92 v6 pickup yesterday. Put all the bolts/nuts back, and was about to start to put the v belt and serpentine belt back on. Realized I forgot to reattach the hose connecting the thermostat to the bottom of the radiator. Oh well, no biggie. Start to remove those 3 nuts. One nut comes off just fine; one the nut wouldn't come off, but the dual threaded bolt came out; and the other won't come out at all.
Turns out that the nut is spinning, so it's not seized, but neither the nut nor the bolt will come out. Don't think PB Blaster or a torch would do anything since it's not seized.
How in the hell do I get this thing out so I can finish my job? Pics attached. Any help appreciated.
Water pump
Bolt/nut
Old Jan 27, 2020 | 10:17 PM
2ToyGuy's Avatar
As a mechanic, I make a real good radar tech...
Having said that, I wager you got the nut down below the threads, that's why it just spins. Try sticking a flat blade screwdriver under the nut while loosening it. You might have to pry a bit. It should re-engage the threads with some pressure under it while turning it. Please note the word "should".
Or maybe a small pulley puller. Put the arms under the nut, the center bolt on the two-ended threaded bolt, and put some pressure under it that way. Hard to try to loosen with a puller attached that way, though...
Alternatively, you can put two nuts on the threads, tighten them down onto one another so they don't move, and use them as a place to put on the wrench to bring the two-ended bolt thingy (technical, aren't I? ) out so you can work on it. You could use something to push on the nut to get it to re-engage the threads. Seems like it would be easier to do with a flathead, like I said earlier.
Last, worst case scenario, get a nut-cutter from a auto parts store, and cut the nut off entirely. Then you have to go buy a new one, but you'd have the old one off, at least.
I know, not the most helpful. Best I got though...
Pat☺
Old Jan 28, 2020 | 09:18 AM
Pat☺
Thanks for the ideas, man. I had the same thought about tightening it past the threads, so I did try the screwdriver trick last night to no avail.
After having dinner I had the idea to cut the nut off. Not sure why I didn't think of that originally, but I think that's what I'm gonna do. Dad will be bringing over some tools I don't have this evening to see if we can get it off.
Old Jan 29, 2020 | 10:52 AM
Co_94_PU's Avatar
The shaft of the stud is as wide as the threads, you can't go past the threads onto a smooth portion of the stud. (Look at your pictures. )
What you gave is a stripped nut and probably the shaft aswell. You gave two nuts right there you just took off, double nut in and extract the stud.
aksarah
Jan 26, 2020 03:25 PM
MikeDAdams
Mar 16, 2012 04:15 PM
bajasurf
Nov 16, 2009 11:34 AM
ryanman
Jun 15, 2009 06:13 AM
