Pre 84 Trucks 1st gen pickups
Water pump removal help
Old Mar 13, 2012 | 10:05 AM
MikeDAdams's Avatar
So my parents just game an 81 pickup 2wd with a 22r.
Drove it home 160 miles.
Moved it the next day and the water pump is leaking.
I have Removed the four nuts from the fluid coupling flange.
Now from what i gather from the manual this should just come off.
This is not the case, am i missing something here?
Thanks in advance
Old Mar 13, 2012 | 11:14 AM
buckshot307's Avatar
there are 6-8 bolts that go through the water pump into the engine and a couple of nuts too i think. you have to remove all of those and then if there is a seal on it you may have to stick a flathead or a small chisel in between the pump and the engine and pry it off
all of the holes on that pic either have a bolt you have to remove or a nut. just make sure you put them all back in the right place haha
Old Mar 13, 2012 | 11:22 AM
MikeDAdams's Avatar
Ok let me clarify. It's actually the fan clutch and assembly that I cannot get removed from the old water pump.
The nuts have been removed and the assembly will not budge, thus I cannot even get back to the pump.
Old Mar 13, 2012 | 11:28 AM
ConSeann3ry's Avatar
Belt is loosened? Give it a whack, should slide right off
Old Mar 13, 2012 | 11:55 AM
MikeDAdams's Avatar
Yeah i pulled the belt off around the fan. i tried getting between the pulley and the fluid coupling (where it meets the pulley, on mine its blue) with a screwdriver and tapping on that between the two did not make a difference. so just smack the blue part a few times and it should come off? I'm just afraid of bending or breaking parts.
Old Mar 13, 2012 | 12:45 PM
uglymudder's Avatar
hey mike, go eat a bowl of wheaties, then try it again. Lmfao!
Old Mar 13, 2012 | 12:47 PM
MikeDAdams's Avatar
It's even funnier if you knew how small of a guy i was
Old Mar 13, 2012 | 01:03 PM
uglymudder's Avatar
I'm on the small side myself, so I use a BFH...a Big F'n Hammer. Sounds like it's been a while since that pulley has been removed. Put a block of wood against it and whack it with a bfh from a couple different directions. Should come off no problems.
Old Mar 13, 2012 | 01:05 PM
BMcEL's Avatar
Hit it with your purse a few more times.
Old Mar 13, 2012 | 01:18 PM
MikeDAdams's Avatar
Yeah its looking like the original pump but its got 350k on the engine.
Old Mar 13, 2012 | 01:19 PM
MikeDAdams's Avatar
Glad to see the family love.
Old Mar 15, 2012 | 08:37 AM
1stgenboy's Avatar
If that doesn't work, save up some change so the purse is heavier and try again.
On the serious side...Use a drift and a 3lb sludge to give the a good rap at the base of the fan clutch where it meets the pully so that the force is sidways or at a 90* angle to the studs. A piece of wood might absorb too much of the force because what your looking for is the sudden jarring of a rap to knock the fine rust loose. .....
1stgenboy
Old Mar 16, 2012 | 04:15 PM
MikeDAdams's Avatar
Ok got it loose.
I ended up with a 2# sledge, a 2x4, and some pb blaster.
Knocked it loose after a few good smacks,
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
jjrbus
Jul 19, 2015 02:06 PM
Snort
Jul 19, 2015 07:03 AM
Jonny246
Jul 12, 2015 04:51 AM
