1st gen dash panel lights on
Old Dec 20, 2019 | 09:09 AM
Scott Mcgill's Avatar
Hi
toyota 4runner: 1987 DLX, 22RE. AT,AC,tilt
Q: AT Temp, Brake and Check engine lights all on?
veery cold up here in VT today but these red lights are all on while idling.
any ideas? thanks
Old Dec 20, 2019 | 08:38 PM
thefishguy77's Avatar
Originally Posted by Scott Mcgill
Hi
any ideas? thanks
Ok first and foremost check the codes. It takes a paper clip and you jump the diagnostic terminals. Then count the flashes and patterns of the CEL. Battery light could be battery or other things same with brake lights. Start easy and figure out what codes it's tripping
Old Dec 20, 2019 | 08:56 PM
ok thanks much, value all tech expertise provided on this site.
where is the diagnostic terminals located? in engine bay, near kick panel at fuse box?
Its about 10 degrees out in the driveway today and this weekend up here in VT so I gotta be quick and steady with the hand
tried sandpaper on all battery terminals etc. , disconnecting battery trying to reboot system in the process, valuebut no solution
where to you view the CEL on the dash?
what is the CEL?
what are the corresponding flashes related to AT temp, or Check engine lite, and Brake?
Not well versed in this type diagnostics obviously.
From reading other things on Yoohoo tech, culprit might be faulty alternator, though replaced 14 months ago as same with new battery
maybe try and limp over to Advance Auto and shame a tech to come out in the cold and test ALT output? and also check Batt output though
it was purchased at Walmart.
Old Dec 21, 2019 | 03:42 PM
Depending on year the location can vary.
Rogers page(s) covers most all you will need to know for the timing and code checking.
https://www.4crawler.com/4x4/CheapTr...CheckConnector
Old Dec 21, 2019 | 04:28 PM
thanks
YotaWoRx
Nov 28, 2013 10:51 AM
Charger92
Apr 19, 2013 02:24 PM
brian.243
Mar 30, 2010 12:29 PM
stagger_lee
Apr 28, 2009 07:54 AM
joshik
Oct 17, 2003 05:02 PM
