95 4runner misfire
Old Nov 28, 2019 | 05:52 AM
Jthompson123's Avatar
95 4runner misfire
New to the forum and not sure if I'm posting in the right section. I have a 95 4runner 3.0 manual that has a misfire on cylinders 3 and 6. Put new plugs, wires, rotor, cap, and fuel injector pig tails. It has a strong gas smell from the exhaust. Not burning any oil, coolant is still full. It will idle at about 1200-1500 rpms. Is there something I'm missing before checking compression. I'm not a mechanic by no means but can do basic and simple repairs. The egr valve has been deleted by the previous owner. Thanks.
Old Nov 28, 2019 | 06:42 PM
superex87's Avatar
I would do a compression check. Are the plugs from 3 and 6 wet with fuel after its been running for a bit?
Old Nov 30, 2019 | 09:37 AM
They were dry and white.
Old Dec 1, 2019 | 07:26 AM
superex87's Avatar
May have some clogged/bad injectors.
Old Dec 12, 2019 | 08:17 AM
Aaron Borhegyi's Avatar
I had injector #1 short on me recently and had to replace the actual inject not the harness. Maybe do an injector service, new orings etc and test them for shorts.
95turdrunner
Oct 16, 2013 12:28 PM
mpdonegancheney
Oct 24, 2012 04:13 AM
vw.dubster
Jan 25, 2010 10:53 AM
tortex53
Jun 2, 2008 01:51 PM
lucky3
Jun 14, 2005 10:22 PM
