Front Bumper
Old Jan 20, 2020 | 01:20 PM
vwrunner's Avatar
Front Bumper
I have learned a lot from this forum and so I thought I would share my latest project. I built this bumper for added protection, since the stock one is pretty weak. I really like the ARB bumper, but I do not need a winch, so I mimicked their design, with a few personal changes. The shell is made of 1/8th inch, and the bracket assembly is built out of 1/4 inch steel plate. I have got some good ideas from this community,
so hopefully my contribution might help someone else.
Bumper before paint. Back of bumper, after paint.
Completed bumper.
Old Jan 20, 2020 | 06:07 PM
RASALIBRE's Avatar
Clean! Thanks for sharing and keep sharing!
Old Jan 21, 2020 | 11:38 AM
old87yota's Avatar
That bumper almost looks as if it could have been a factory option!
Great job!
Old Jan 21, 2020 | 11:44 AM
itscrazytom's Avatar
That's clean. How much did it cost you to build that?
Old Jan 21, 2020 | 12:15 PM
1stgen88t4r's Avatar
I have the same year and model, but think it would look much better on mine. I'll send you my address
Old Jan 21, 2020 | 07:13 PM
vwrunner's Avatar
Thank you for the kind words.
itscrazytom - I had left-over steel from other projects, it basically cost me around $20 for some primer and paint. I am fortunate enough to have a friend that has a plasma table and a press-brake. I am working on a skid plate and will post some photos of it soon.
Old Jan 21, 2020 | 07:31 PM
Oldcarnut's Avatar
That is one clean bumper you have there. I'm in the same boat as wanting a good bumper and not needing a winch. I am not really a fan of tubes nor stingers unless on a purpose built 4X4 I will say that the winch box makes a good storage bin if a top is available though.
Old Jan 22, 2020 | 06:59 AM
jakey poo's Avatar
In that case I will double your invest for it! It really does look great!
Old Jan 22, 2020 | 11:21 AM
5 Fists's Avatar
Really nice looking bumper! A plasma table and press brake definitely make fabbing things up a lot easier.
Can you take a close up pic of the outside corners, would like to see how you bent them up.
Old Jan 23, 2020 | 02:48 PM
vwrunner's Avatar
5 Fists, that is so true. I built the rear bumper without that special equipment and it took a lot longer and it didn't turn out as good. Here is a photo of it. I think it turned out OK, but you can see that the bends are not as smooth, nor as gradual as the press brake bends on the front bumper, and I went though quite a few cut-off wheels to cut everything out of the sheet of steel.
Here is a close-up of the corner, as requested.
Old Jan 23, 2020 | 06:39 PM
5 Fists's Avatar
Very cool! Thanks for the closeup.
Old Jan 24, 2020 | 05:15 AM
rattlewagon's Avatar
awesome job. need more post like this on the forum.
Old Jan 24, 2020 | 07:29 AM
yotabiff's Avatar
Nice job,good looking rig,what size tires u got?
Old Jan 24, 2020 | 07:35 AM
5 Fists's Avatar
Are they powder coated, or just spray painted?
Old Jan 24, 2020 | 08:38 AM
vwrunner's Avatar
Yotabiff, I am running 33 x 10.5 tires. I like the height of this size, but I don't like a very wide tire. Besides, my rims are 15 x 7, so running a 12.5 wide tire is pushing it. I used to have 33 x 12.5's on these rims and I didn't care for it much.
5 Fists, I am a do-it-yourself budget builder, therefore the bumpers have a rattle can spray paint job. I figured the bumpers would end up getting scratched up anyway.
Old Jan 24, 2020 | 08:48 AM
vwrunner's Avatar
Skid Plate
I never had the factory skid plate for my 4Runner and the ones at the junk yard were either horribly bent-up or missing, so I figured I would make one. It is made of 3/16th inch aluminum plate. Here are some photos.
Cut and bend skid plate
Rear view
I forgot to mention that when I built the bumper, I incorporated two reinforced jack-points. I tested it out and it holds the vehicle without any drama.
Old Jan 24, 2020 | 12:12 PM
5 Fists's Avatar
Pretty awesome rattle can job! I thought for sure they were powder coated. You're inspiring me to get back on some of my custom stuff!
Old Jan 24, 2020 | 06:29 PM
vwrunner's Avatar
Right on! Happy to be of service.
Old Jan 25, 2020 | 02:26 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
self built bumper
"I forgot to mention that when I built the bumper, I incorporated two reinforced jack-points. I tested it out and it holds the vehicle without any drama."
Nicely done, sir. I thought there were animated emoji's for humbled adulation, but can't find one. It applies just the same.
Old Jan 29, 2020 | 06:09 AM
Genera_lee's Avatar
looks sick! makes me want to finish up my designs and get them tacked together
