High idle at cold start.
Old Mar 2, 2026 | 04:57 AM
dsc194's Avatar
I have a 93 Toyota truck 22re engine, the truck has a high long idle when starting cold. The idle goes up to about 2100 rpms and will stay that way for way to long. The idle doesn't come down by hitting the gas pedal. The truck doesn't have this problem when the outside temperature is in the 90s or after the engine gets warm. I was thinking maybe a idle air control valve not working properly. Has anyone had this problem? Any help or advice would be appreciated.
Old Mar 3, 2026 | 10:45 PM
aztoyman's Avatar
It's been a long time since I worked on 22RE's but I do remember my son's 91 and 93 had similar issues and it was the IAC valve. One of them we took apart and cleaned up and it solved the high cold idle but the other required a replacement of the valve. So you had a good hunch and place to start looking.
Good luck with it and please follow up. You may help others down the road.
Scott in AZ.
Old Mar 4, 2026 | 06:11 AM
dsc194's Avatar
Originally Posted by aztoyman
It's been a long time since I worked on 22RE's but I do remember my son's 91 and 93 had similar issues and it was the IAC valve. One of them we took apart and cleaned up and it solved the high cold idle but the other require a replacement of the valve. So you had a good hunch and place to start looking.
Scot tin AZ.
I'm currently waiting to make some room in the garage, it's full of my wife's house plants. I will try to clean it first and report back. Thank you for the help.
buckz6319
Aug 4, 2009 03:08 PM
Ozkar
Apr 8, 2009 07:48 PM
91Toyota
Oct 23, 2008 08:21 PM
Dezertoyota
Apr 20, 2007 05:42 AM
