'91 scanner & check engine light
Old Mar 20, 2013 | 05:52 PM
maachine's Avatar
my neighbor bought a 91 toyota rv. he is an old man so i help him a lot. when he bought it his son ran the exhaust pipe into the mud clogging it up and turning on the engine light. pretty sure its just O2 sensors but i need a scanner.
its a 3.0L 6 cylinder. i have an OBD 2 scanner but dont have the correct adapter. do i have the right scanner? and where can i find the correct adapter to plug the scanner in? thank you in advance.
Old Mar 20, 2013 | 06:01 PM
rworegon's Avatar
The scanner is a paper clip, I believe. There are threads around here on how to read the codes.
Old Mar 20, 2013 | 06:38 PM
maachine's Avatar
thanks. did some research and found this for anyone needing this info in the future. they started OBD 2 in 94 so this truck is OBD 1. on this RV, plug is on passenger side strut tower, not drivers side.
http://www.troublecodes.net/Toyota/
scope103's Avatar
What sayeth the Good Book? http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
As rworegon mentioned, the SST is a paper clip.
Old Mar 20, 2013 | 06:41 PM
maachine's Avatar
thank you for that, even better resource
Old Mar 21, 2013 | 04:09 PM
maachine's Avatar
thanks again guys. just went over to my neighbors house and fixed up his rv. it was code 25, lean mixture, which can be caused by an overheated O2 sensor. with a plugged exhaust pipe....i can see that happening. thanks again
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
