cam and crank seal drivers?
Old Mar 29, 2013 | 06:47 AM
easterly81's Avatar
I got the crank seal out last night and if i can ever get the cam sprockets off, im going to change the seals. I was wonder what people use to drive the new ones in?
Old Mar 29, 2013 | 07:03 AM
93toyrunner2's Avatar
A socket the same size and a rubber mallet.
Old Mar 29, 2013 | 07:43 AM
scope103's Avatar
Do you have the oil pump removed from the engine? http://personal.utulsa.edu/~nathan-b...118oilpump.pdf If not, I don't think any socket will fit over the crank shaft. You might have to fab-up something using PVC pipe (I've never done this, so I can't give you any sizes. But you'll report back the sizes and what you did, won't you?)
Do you have the valve covers off? The cams have a 27mm flat forged into the middle, where you can put a wrench to resist the torque on the cam sprocket bolts. (This is arguably better than holding the cam sprocket with a special tool; holding the cam sprocket transmits the torque through the knock pins and the sprocket.) 27mm is not that easy to find, but 1 1/16" is easy to find, and the difference is size is below what you can measure.
bigjstang
Jun 2, 2025 03:56 PM
thefishguy77
Jul 30, 2015 10:59 AM
CanRunner
Jul 20, 2015 01:29 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
coryc85
Jul 6, 2015 04:07 AM
