Vacuum issues? No 4wd
Old Apr 4, 2013 | 08:56 AM
RaunchBox's Avatar
I have a 1990 4runner v6. The 4wd was working when i bought the truck. Me and a friend did the head gasket replacement and put it all back together. Now I dont have a 4wd light and front tires dont spin. I can hear a click from what i am assuming the relay in the dash when i shift into 4. I can also get low. I lock the hubs but i still dont have 4wd. The light does not come on. I had a vacuum issue where i had a rough idle but i believe i have fixed that by reconnecting the power steering vacuum lines last night. They were damaged. It idles better it seems, but still no 4wd. What lines should I follow? Can somebody please be kind enough to post a pic of where the lines come out and where they connect to the ADD?
Thanks for all of your help!!
Old Apr 4, 2013 | 09:37 AM
yodafan93's Avatar
auto hubs?
Old Apr 4, 2013 | 09:59 AM
vasinvictor's Avatar
There are 2 vacuum lines that run to the front diff, at the ADD vacuum actuator. I'll bet you've pulled 1 or both of them loose. They should run down the passenger side in the engine bay and wrapped in some kind of braided black plastic.
Old Apr 4, 2013 | 10:01 AM
See if this thread helps https://www.yotatech.com/forums/f116...estion-113564/
Old Apr 4, 2013 | 10:41 AM
RaunchBox's Avatar
Originally Posted by yodafan93
auto hubs?
manual hubs.
And thanks for the info.. I will take a look at them.
Old Apr 4, 2013 | 10:42 AM
RaunchBox's Avatar
anybody have pictures of the actuator?
Old Apr 4, 2013 | 11:55 AM
scope103's Avatar
Originally Posted by vasinvictor
At the end of the thread cited by vasinvictor. Not the best, but they'll tell you everything you need to know.
Old Apr 5, 2013 | 04:05 AM
RaunchBox's Avatar
Thanks for your help! Will look into this weekend and let you all know what I find out..
Old Apr 9, 2013 | 05:50 AM
RaunchBox's Avatar
Fixed it thanks guys. The VCV that was plugged into a non vacuum line... swapped it and its good to go. THX!!
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
