Back window help
Old Mar 31, 2013 | 06:47 AM
95 4runnerv6's Avatar
Back window help
My back window works fine with the key both up and down but using the inside button it goes down but won't go back up using the button. I have a 95 4runner 3.0. Can someone help. Thanks for advise in advance
Old Mar 31, 2013 | 07:38 AM
skinny's Avatar
this could be good I have a 94 only works off button no key action
Old Mar 31, 2013 | 07:44 AM
wyoming9's Avatar
Red face
In both cases have you checked that the switch indeed works like it should .
Even on Toyota vehicles things do wear out and break!!
Sometimes wires get damaged
Old Mar 31, 2013 | 05:25 PM
rbuchmann's Avatar
Remove the switch and with a test light and your finger in the up position, see if you're getting power out of the Up side of the switch with all the wires connected. If not, its probably the switch. If you are, then you'll need to trace out the problem. Mine works from the switch, but not the rear key. Gonna figure that out tomorrow. More than likely my switch is bad in the back. Maybe I can fix the switch myself. If not, I'll replace it.
Old Mar 31, 2013 | 10:10 PM
a51young's Avatar
There is a circuit board, relay box behind the trim, drivers side on my 90, could be a bad relay. Could be the wire from the switch to the box is broke. I had a similar issue, key down wouldn't work so I ran a new line from the key switch to the relay box to fix my issue.
The relays are easy to fix, plenty of thread with info about a good replacement relay. There are four of them for the stuff in the back there.
Old Mar 31, 2013 | 11:44 PM
wyoming9's Avatar
Red face
it is just easier to test the switch first before pulling the trim off at least to me.
Jun 1, 2021 01:51 PM
87blyota
Jul 10, 2015 04:31 AM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
elwood73
Jul 5, 2015 07:07 AM
