no heat inside, well just alittle
Old Mar 30, 2013 | 09:39 AM
slopedogg's Avatar
i own a 90 4runner, it get hardly any heat thru the def. any advice for me.
thank you
Old Mar 30, 2013 | 10:09 AM
rworegon's Avatar
Coolant heater valve under hood working?
Cables in dash working?
Heater core plugged?
Old Mar 31, 2013 | 11:45 AM
slopedogg's Avatar
Where is the coolant heater value locate at under the hood?
Old Mar 31, 2013 | 12:13 PM
Discombobulated's Avatar
Have you ever used any stop leak for any radiator coolant leaks??
Old Mar 31, 2013 | 12:21 PM
Co_94_PU's Avatar
On the firewall, kinda hard to miss should be the only one up there. Connects between the engine and heatercore, has a little cable running to it from the climate control inside the cabin.
Consult the Book!
slopedogg's Avatar
Well just put a new radiator in and coolant hose. Here is a small leak back by firewall, but it doesn't leak inside. So it can't be the heater core, could it be the heater core?
Old Mar 31, 2013 | 12:23 PM
Co_94_PU's Avatar
Old Mar 31, 2013 | 12:24 PM
slopedogg's Avatar
Find the heater value
Old Mar 31, 2013 | 12:30 PM
scope103's Avatar
Note the small bell-crank at the bottom of the valve; it moves with the temperature control (and if disconnected, doesn't move.)
puddlepirate
Jul 30, 2016 06:29 PM
Davebarbier
Nov 3, 2015 03:28 PM
mreagen
Oct 5, 2015 04:27 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
Matthew Perez
Sep 28, 2015 05:43 PM
