Factory skid plate bolt size?
Old Mar 21, 2013 | 05:34 PM
MattRX's Avatar
I picked up a factory skid plate off cl. Does anyone know the factory bolt dimensions or part #? I've searched and haven't found much. My truck is an 88 btw. Thanks.
Old Mar 21, 2013 | 06:01 PM
a51young's Avatar
For my 90 4runner, part number 90119-08766
This should work
http://www.autozone.com/autozone/acc...er=988250_0_0_
Don't know the size or thread pitch though, but I use a 12mm socket on them
Old Mar 22, 2013 | 06:04 AM
Pat8942's Avatar
I know this isn't the right part, but a 5/16 18 standard bolt will screw right in the toyota bolt is 8mmx1.25 I don't know the length.
Old Mar 23, 2013 | 09:37 AM
MattRX's Avatar
Thanks
Thanks for the quick replies fellas.
Old May 3, 2018 | 07:14 PM
RAD4Runner's Avatar
Stripped Thread. Re-thread for 10-mm dia 1.5mm pitch?
Yes, stock bolt is 8mm - dia 1.25mm pitch...
One of the threads for my skid plate is stripped, and the others are starting to get there, too. I believe there is a nut welded to the frame, correct? Meaning there's room to re-thread for 10-mm dia, 1.5-mm pitch bolt?
Has anybody successfully done that?
keywords: skidplate, skidplatebolt, skidplatemount, skidplatemounting
Old May 4, 2018 | 04:28 AM
rickc5's Avatar
Here's a tip for skidplate bolts. I buy stainless bolts at a local screw, bolt & nut store--that's all they sell. You'll have to ask around.
Then, before installing (every time), smear a bit of anti-seize on the threads. They bolts won't rust, they'll come out much easier, and chances of messing up the "nut" are reduced.
88sasturbotoy
Jan 30, 2026 01:57 PM
kgcwb44
Jan 29, 2023 10:02 AM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Sep 4, 2015 09:27 AM
