Can anyone post or link to a healthy sounding 22R/E?
Old Apr 2, 2013 | 10:09 PM
saltandgranite's Avatar
Mine sounded fantastic until I had to do the HG job. Since then I've readjusted my valves twice and can't seem to remember what it should sound like. I don't remember noticing any valve noise prior to the job, and now it's all I hear. On youtube I can only find 22R/E engines that have issues....
I know some valve chatter is normal, but my engine only has 34k original miles on it... it shouldn't be too noisy?
So let's hear your 22Rs!
Old Apr 3, 2013 | 09:26 AM
Okay, since nobody wants to post their 22Rs - can anyone just tell me if it's normal to have valve clatter when cold? The engine sounds great when warmed up but sounds like a diesel when cold....? Just want to know if I need to get back in there. Thx.
Old Apr 3, 2013 | 09:56 AM
snobdds's Avatar
The fuel injectors on these trucks are noisy. Are you sure you're not hearing the ticking of the fuel injectors...?
Old Apr 3, 2013 | 10:03 AM
cman1's Avatar
my 22r is pretty noisy below 10 degrees, but quiets down when it warms up.
Old Apr 3, 2013 | 10:07 AM
It's carbureted.
Here's a quick vid about how it sounds. It was late and it's dark so hard to tell where I have the phone mic, but as the knock/tick gets louder the mic is just above the valve cover. This is cold. When warm there is just about no knocking/ticking whatsoever:
[YOUTUBE]http://www.youtube.com/watch?v=ZLEM-...ature=youtu.be[/YOUTUBE]
Edit: Not sure how to embed that...
Old Apr 3, 2013 | 10:16 AM
cman1's Avatar
make sure your valve cover isn't too tight, only 9ft lbs, or finger tight then a quarter to half turn. to check ,start it up,back the valve cover bolts of a little at a time,if the noise goes away,easy fix. otherwise go through the valves again,takes nothing but time.
Old Apr 3, 2013 | 10:24 AM
snobdds's Avatar
Originally Posted by saltandgranite
It's carbureted.
I dregress...
Old Apr 3, 2013 | 10:39 AM
Thanks. I'll check it out. Would the chatter go away once it warms up if this was the issue? I'll try to post a video of it idling warm in a bit, but it makes a huge difference.
Old Apr 3, 2013 | 11:24 AM
cman1's Avatar
no.it will stay the same. your probably just anal like me...needs to be quiet!
Old Apr 3, 2013 | 11:41 AM
One more thing, the engine only has 34k original miles on it. So nothing should be worn. Just did HG (4k ago) and everything looked great.
Old Apr 3, 2013 | 04:35 PM
xylicon's Avatar
Here is my 22RE, skip to the end for under hood sound
Old Apr 3, 2013 | 05:36 PM
Wow they really do sound like typewriters... was that warm or cold? That's about what mine sounds like cold. Thanks a bunch for posting that. How many miles, when was last valve adjustment?
Old Apr 3, 2013 | 05:45 PM
BK2TFUTURE's Avatar
Just rebuilt
Old Apr 3, 2013 | 06:28 PM
Hot damn that's a clean engine. I've been following your thread, congrats! When are you going to paint the exterior?
Old Apr 3, 2013 | 06:40 PM
xylicon's Avatar
That video was taken back when that motor barely had 1000 miles on it. I had just adjusted the valves the day before I took that video.
Old Apr 3, 2013 | 07:01 PM
BK2TFUTURE's Avatar
Thanks!! I dropped her off Monday. Probably be done around mid May.
Old Apr 3, 2013 | 07:28 PM
pittman_justin1988's Avatar
My 22r does the same when cold and it was rebuilt too all of them spund like sewing machines its normal
sandyota
Feb 4, 2021 11:16 AM
yourrealdad
Jul 21, 2015 11:13 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
ptb12
Jul 5, 2015 01:49 PM
