all the anti freeze was in the tank on the right and over flowing
ok today i drove my 93 4runner and when i got home all the anti freeze was in the tank on the right and over flowing but the hand stays in middle but idk if the hand works whats the problem
Last edited by waskillywabbit; 04-23-2009 at 06:40 PM. Reason: Title clarity per posted sticky
Doesn't mean the HG didn't go again. Who re-installed the heads? Were new headbolts used? Was the proper headbolt torquing method used? Were the headbolt threads lubed before they were installed? There are a lot of possibilities of why you get insufficient clamping force from your headbolts, all of which can lead to blown headgaskets.
Please use specific thread titles and not "help please" etc. This greatly helps future searchers with perhaps similar problems to find answers and builds our database.
Look here for details.
https://www.yotatech.com/forums/f2/p...-notice-74566/
Thanks!
Thanks!
1 Post
Your water pump has spun so fast it created a hole which allowed air in, then it literally blew all of your antifreeze/coolant into the overflow bottle. Any motovation to fix it will b met with equal opposition by the 3.0 Demon.
No. j/k. Do a compression test in the all of the cylinders. It will give us a better idea of "whassssssssssss uppppppp".
Just for explanation, there is a "low line" and a "full line" on your overflow bottle. When the coolant is cold, the level in the bottle should be at the "full line", and the rest of your cooling system should be full with no air pockets in it. You'll notice there is some room in the overflow bottle above the "full line". When your engine warms up, the increase in temperature of the coolant will cause the coolant system pressure to increase, as the volume of coolant expands. When the pressure reaches the radiator cap's setpoint (around 15psi, if I remember correctly), the relief valve in the cap will open as required to maintain that pressure. The "extra" volume of coolant gets released into the overflow bottle (that's why you need to leave room in there above the "full line").
When the engine cools down, the coolant volume is reduced, and the "extra" volume of coolant from the overflow bottle gets drawn back into the radiator through the cap as the pressure drops in the cooling system.
You can get a shop (if they have a rad cap testing tool) to pressure test your rad cap to see if that's the problem. I hope it is, but it doesn't sound as likely now that you gave us the details about the shop that re-installed your heads.
It's good that your problem seems to be gone. As mentioned before, you should do a compression check just to be sure.
Drive it around enough to get the cooling system up to normal temperature and keep an eye on the overflow reservoir level. It sounds like you might have gotten off easy this time.
