Rear window relay temp fix
Old Apr 26, 2009 | 09:06 PM
smallenginemechanic's Avatar
The rear window would not go up unless you pressed the button 100 times. No problem going down. I opened up the relay box and found the relay had burnt through the connecter so deep it wasn't contacting it anymore. I scratched the burntness off, and bent the tab down just a hair so it would contact again. Window works flawlessly. This is not meant as a permanent fix but as a temp untill you can follow matt16 https://www.yotatech.com/forums/f116/rear-window...runner-137193/ and his walkthrough.
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
coryc85
Jul 6, 2015 04:07 AM
ptb12
Jul 5, 2015 01:49 PM
