1990 4runner OverDrive Not there
Old Apr 24, 2009 | 08:31 AM
dnfnate's Avatar
I have a 1990 4runner 4x4 v6 and when it shifts into over drive it the trans free spins as if it was in neutral. I drove it home last night with the over drive off 80 miles no fun at 45 mph.
does anyone know if this is a electric problem or just the trans is bad?
thanks
Nate
Old Apr 24, 2009 | 08:59 AM
Marc's Avatar
Welcome. Sorry I can't tell you what's wrong but you should be able to go faster than 45 with the O/D off.
Old Apr 24, 2009 | 09:03 AM
dnfnate's Avatar
that is what i was thinking. It feels like it in 2nd the whole time.
Old Apr 24, 2009 | 09:56 AM
Tubbyfatty's Avatar
Well, over drive is just another gear for highways that lowers your rpms. So when you take OD off it just uses one less gear.
You can go faster then 45 but the rpms will just shoot up because its in 4th or 3rd.
Old Apr 27, 2009 | 10:39 AM
dnfnate's Avatar
i just picked up a good trans for $140 :-) going to put it in today.
thanks
nate
Old Apr 27, 2009 | 11:30 AM
Marc's Avatar
Good luck with that.
Old May 20, 2009 | 08:06 PM
moegaz's Avatar
you could have tried putting in new shifting solenoids that or its another on of Toyota's infamous blunders, a vacuum leak. but for a new trans. for 150 WOW what a deal hope it works out for you
Old May 23, 2009 | 04:23 PM
R.DesJardin's Avatar
A340
A340's won't free spin with bad solenoids. They only control the shifting gear selection. If no solenoids work then you would be stuck in OD. The free spin in only one gear sounds like a freaky thing. While your changing trans. maybe add a good trans. cooler.
Flying91
45
Apr 11, 2024 04:39 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
BeMiceElf
Oct 10, 2015 09:40 PM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
