Electrical Problem. Need help.
Old Apr 26, 2009 | 11:06 AM
hoppa's Avatar
I just installed a 120 amp alternator, I installed 5 ga. cable from the alternator to the fuse box. I also installed a 5 ga. cable from the other side of the fuse to the battery, also installed a 120 amp fuse in place of the 80 amp.
I hooked evey thing back up and I have no power to the inside of the cab (dash lights, starter clock). Ther is power to the fuse panel in ds kick panel because theres a relay clicking when I turn the key.
The head lamps work the hazard lights work. I checked all the fuses in the kick panel and uder the hood all seem good.
Its an 88 4 runner and was working fine before the swap except for the batt and charge lamp staying on which is why I replaced the alternator.
Any help would be greatly appreciated.
Thanks
Old Apr 26, 2009 | 12:12 PM
hoppa's Avatar
Never mind I got it.
Old Apr 26, 2009 | 12:50 PM
elblako91's Avatar
what was it?
Old Apr 26, 2009 | 02:57 PM
desert-rat660's Avatar
dead battery?
Old Apr 28, 2009 | 03:02 PM
hoppa's Avatar
Aparently there is something in the stock harness that is needed for the cab to have power. I wired up the stock charge wire and walah, power.
As soon as I get more time ill figure out what I missed and go back with the 5 ga. cable.
Old Apr 28, 2009 | 04:54 PM
dntsdad's Avatar
hmmmm......never even heard of 5 gauge cable before.
Old Apr 28, 2009 | 11:52 PM
wyoming9's Avatar
I was also thinking the same thing.
I have never seen that size in the United States .
What did you use???
Old Apr 29, 2009 | 07:35 AM
TNRabbit's Avatar
you can use the stock wire AND the 5 gauge cable directly to the battery in tandem. Problem solved.
Old Apr 29, 2009 | 11:26 AM
mt_goat's Avatar
Yeah IIRC the stock harness splits off and one group of wires goes into the drivers side fender (maybe to the in-cab fuse box ) while the rest go around to the under-hood fuse box. I'm running dual or tandem alt cables with no problems.
Old Apr 29, 2009 | 11:33 AM
AZkid's Avatar
oh my god! thats whats wrong with my truck!! same exact thing!!!!
Old Apr 29, 2009 | 11:47 AM
mt_goat's Avatar
Yeah you see it in this pic, the lower white cables are the stock harness unwrapped up to the split (1&2). The upper black cable is the one I added:
markwink
Aug 18, 2015 12:38 PM
izzmee
Aug 17, 2015 10:20 AM
corey519
Aug 12, 2015 11:12 AM
Yota.Jay
Jul 23, 2015 08:08 PM
