1995 Power Window only goes down
Old Aug 6, 2017 | 10:40 AM
lecktrix's Avatar
Hello all.. I have a 1995 4runner and the passenger window will only go down. I have changed the switch, checked motor(good) Its the passenger front. Any help would be appreciaed!!
Old Aug 6, 2017 | 11:14 AM
lecktrix's Avatar
Update... Does not operate from the drivers side at all... All other windows work perfect... Pass door window will only go down from the pass switch.. I pulled the control module and I dont see any burnt issues.
Old Aug 6, 2017 | 12:28 PM
wyoming9's Avatar
Red face
Broken wires going into the right door
Old Aug 7, 2017 | 01:31 PM
RAD4Runner's Avatar
Originally Posted by lecktrix
... I have changed the switch, checked motor(good) Its the passenger front. ...
Stop replacing things that you are not absolutely sure are broken, cost you money and not fix the problem.
How did you check the motor?
When you pushed to UP position what voltage did you get at motor?
When you pushed to DOWN position what voltage did you get at motor?
Gen1Runner
101
Apr 8, 2018 02:25 PM
881stgen
Apr 30, 2017 03:42 PM
Land yacht
13
Sep 10, 2002 01:11 PM
Briareus
10
Aug 24, 2002 05:33 PM
Krash
10
Jul 13, 2002 09:21 PM
