Steering and Linkages IFS with Torsion Bars 1986-1995
Hi guys, this could be a good inclusive thread for category: "Steering and Linkages for IFS with Torsion Bars 1986-1995"?
I checked steering linkages for play. Here are the videos. Would appreciate your second opinions (second set of eyes).
CHECKING PITMAN ARM:
Right wheel is on ground, Left Wheel is off the ground. I'm trying to turn left wheel by grabbing it at 3 and 9 O'Clock positions. I see play at the knuckle / ball-joint? (most noticeable by looking below the rubber boot).
CHECKING IDLER ARM:
Left wheel on ground, right wheel off the ground. Trying to turn wheel with hands at 3 and 9 O'Clock positions.
I see no play from bushing, only at the elbow/ball-joint as shown.
Is that considerable play at the knuckle (most noticeable below the rubber boot)?
LEFT TIE-ROD END:
Right wheel on ground, left wheel off the ground. Trying to turn left wheel with hands at 3 and 9 O'Clock positions. I do not see play.
RIGHT TIE-ROD END:
Left wheel on ground, right wheel off the ground. Trying to turn left wheel with hands at 3 and 9 O'Clock positions. I do not see play.
Yes, I'm aware of the posts about replacing idler arm bushings but I do not see play on the bushings. The knuckleS are not replaceable, are they?
CHECKING IDLER ARM:
LEFT TIE-ROD END:
RIGHT TIE-ROD END:
Thanks, guys!
Toyota Parts Deal came back with me with answer to my parts question about pitman arm...
'...correct pitman arm is part# 45401-35220.."
here it is on TPD's website...
Now my main question is: Do you think the play observed above at knuckle / ball-joint of idler arm and the pitman are are normal, or do they mean I need to those parts replace soon?
Did you observe any play like I observed above before you replaced yours?
Do you think the play I observed at knuckle / ball-joint of idler arm and the pitman are are normal, or do they mean I need to those parts replace soon? TIA
That's OEM from Toyota Parts Deal. May we know where you got your great deal?
Thanks a lot!
Rad, it's more difficult to judge with video than in person but i would not say that your stuff looks loose with the possible exception of the idler arm but you are only showing half of it. My idler was much worse and one reason my truck failed the first state inspection. Also, i find it easier to have another person rock the steering back and forth with the wheels on the ground and truck running to observe play in the tie rod ends. If you turn fully to each side you can bounce it off the limit. Did you check ball joints while you were down there also?
Solid links are all good. Steering while driving is tight. But again I wanted to look at each component that could have play:
1) Idler arm
2) Pitman arm
3) Tie-rod ends left and right.
