Front differential leak
Old Jul 15, 2017 | 06:50 PM
Katoner's Avatar
ok so This time I m dripping a little from the front dif. Thought pinion seal but seams to come from the front plate, breather seems fine, is that a common issue?
Not sure of the history of the truck (4r 1990 5so 22re)... 285k miles.. is there supposed to be gasket sealant here??
Thanks
Old Jul 15, 2017 | 07:05 PM
millball's Avatar
If you're sure it's coming from the cover, open it up and reseal it.
Gotta be degreased perfectly with acetone or the sealer won't stick. Other than Toyota FIPG, I think Permatex Ultra-Grey works best.
These front diffs often leak from the short axle stub as well. give that a good look.
Old Jul 16, 2017 | 05:43 AM
Katoner's Avatar
ok i will check around the axle thanks. i notice it only see oil drop after a ride, when the car sits oil doesnt drip, not sure if that means anything in particular?
Old Jul 16, 2017 | 08:22 AM
millball's Avatar
if it only leaks after use, it might indicate the axle seal, or pinion seal is the culprit.
Old Jul 16, 2017 | 12:30 PM
Katoner's Avatar
thats it!
Can't find writeup on that, how hard a job? Can I change the gasket with CV attached to stub?
Old Jul 17, 2017 | 10:55 AM
Katoner's Avatar
Spent a couple hours searching but I'm getting comfused about what I need to do here, or even what I'm looking for!. The 4crawler writeup is for solid axle I think?? Is it the inner axle seal what I'm looking at replacing or is the inner seal part of the axle? What is that stubby axle called?? Anyone know of a writeup for this particular thing?
I have changed the axles on my truck recently.. if I remove the axle again, can I just then remove the stubby axle and access the seal?
thanks for the help. Excuse my newbness
Old Jul 18, 2017 | 11:15 AM
Katoner's Avatar
I think I found it. looks like im ready to get started..
Old Jul 19, 2017 | 02:16 PM
Katoner's Avatar
Started to tackle this but looking at the differential plate how it is bolted on the front I'm wondering if I can do this without dropping the differential entirely? And if it is doable then do I have to support the differential when removing the front plate and drivers axle so it doesn't drop?
thAnks
Old Jul 19, 2017 | 03:26 PM
dark_fairytales's Avatar
I have had the front out a few times its not hard and well worth it if you need to clean it ( the second time I pulled it I did not even use a floor jack). Also keep with the red RTV it is much easier to clean off and the grey is not needed as there is not much pressure build up, it sucks to try to pry the front cover off with the grey RTV. There really is not much to the job, just a little time consuming.
Old Jul 19, 2017 | 03:47 PM
Katoner's Avatar
nice thAnk you!
scoostraw
Apr 16, 2017 07:58 AM
stratejacketbillybob
Apr 11, 2017 11:47 PM
OverEazy85
Apr 9, 2017 03:41 PM
bogginyota
Mar 26, 2017 12:38 PM
