the famous 3.4 swap
Old Jul 29, 2017 | 06:00 PM
Knix47's Avatar
the famous 3.4 swap
delete
Old Jul 30, 2017 | 01:08 AM
wyoming9's Avatar
Red face
Maybe read through the 3.4 Swap section.
Do lots of research before spending a cent.
Get the Toyota EWD`s for the donor vehicle and yours
Pretty much drag the complete donor vehicle home so many little things we all tend to forget the days and money you save is well worth it.
Buy a running engine if at all possible out of a vehicle you can pull the codes. Nothing like finding out the ECM and most of the senors no longer work after it is installed.
Exhaust do what you want .
Are you a Hard core off Roader ?? If you need the ground clearance building a Cross Over pipe is your best option if not you can put the crossover on the bottom
In my world Affordable and swap never seem to go together .
Then there always seems to be the trouble shooting process to get all the codes cleared
