vibration at low speed
Old Nov 8, 2009 | 04:46 PM
Brendan's Avatar
in neutral only and only at speeds below 25mph. ujoints are all good.
ideas?
Old Nov 8, 2009 | 04:58 PM
buckz6319's Avatar
vibrations are hard to pinpoint
just some suggestions.....
have you checked your wheel bearings for play?.....bearings on the front short stub axles where the cv flange bolts to that flange (assuming you have a ifs)?...warped rotors?.....
Old Nov 8, 2009 | 05:02 PM
wii_tarded's Avatar
balanced tires? what is vibrating?
Old Nov 8, 2009 | 09:38 PM
desertcamper67's Avatar
separated tire?
Old Nov 9, 2009 | 08:06 AM
Brendan's Avatar
haven't checked the wheel bearings - i'll do that. it's definitely not warped rotors and i guess it's possible that a wheel weight could have fallen off, but wouldn't the vibration be more noticeable at higher speeds? as for exactly where the vibration is coming from, i'm not sure. somewhere in the front half of the vehicle, that's all i can tell.
i've also got a vibration in 4wd when i let off the gas pedal with the tranny in gear, but it is more noticable by ear than by feel. i don't think the two are related.
Old Nov 9, 2009 | 08:21 AM
buckz6319's Avatar
you may try removing the rear drive shaft and just drive in front wheel drive...that may help you know if it truly is coming from the front or rear of the shaft it self
I have simular vibration and have about 25 threads on it.....so I fell for you and I haven't figured out where my vibration is coming from yet and neither has 10 repair shops
ghostmoney
Jan 28, 2018 11:42 AM
montanatruck
Feb 26, 2017 07:07 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
