water leaking on drivers feet...HELP
Old Nov 12, 2009 | 05:36 AM
stacme's Avatar
My dughters 1995 4runner leaks water on the dirvers feet when driving and it is raining. Where is this water coming from? Does this only when it rains and you are driving.
Seems like it is coming from up high under the steering console. Drips and then sometimes even pours. Please help if you have any idea where the water is coming from and how to fix. THANKS
Old Nov 12, 2009 | 09:20 AM
elblako91's Avatar
Seems like it could be the evaporator box for the A/C system. Does this happen when the A/C is on? Leave it parked over night and then drive it the next day with out the AC on and see if it leaks. What your describing is the same thing that happened to me.
Old Nov 12, 2009 | 10:00 AM
olharleyman's Avatar
check for leaves and other debris clogging the drain and trap also check the cabin filter
Old Nov 12, 2009 | 10:25 AM
elblako91's Avatar
Also does it leak/pour really cold water when you go around a turn?
Read this thread..... AC THREAD
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Jonny246
Jul 12, 2015 04:51 AM
Avenged
Jul 9, 2015 07:55 AM
coryc85
Jul 6, 2015 04:07 AM
