Valve sticking
Old Nov 8, 2009 | 03:14 PM
davo247d's Avatar
Valve sticking
so ive got the valves for piston #4 on my 22re sticking to the point where the piston will un-stick the intake, i just had the head resurfaced and i was wondering if the hot tank would have anything to do with that?
Old Nov 8, 2009 | 04:23 PM
Myron's Avatar
Just curious, but how do you know that the valves are sticking?
Old Nov 8, 2009 | 04:36 PM
davo247d's Avatar
pulled the valve cover off and the springs were compressed
Old Nov 8, 2009 | 05:57 PM
davo247d's Avatar
should i run a litttle sea foam? any sugestions? any help would be very much apprecieted!
Old Nov 8, 2009 | 06:40 PM
Myron's Avatar
i ran half a bottle seafoam in my engine and a whole bottle in my gas..my truck sounded much better and felt different in a good way..
Old Nov 8, 2009 | 10:11 PM
limon32's Avatar
If you just had the head off and hot tanked, I doubt SeaFoam will help your problem as you shouldn't have enough sludge or carbon buildup to interfere with valve operation that fast.
What else did you do to the head? Sounds more like a mechanical interference issue to me.
Old Nov 8, 2009 | 11:08 PM
flyingbrass's Avatar
What do you mean the piston will unstick the intake?
Did you have engine and cam positioned at TDC when you installed the rocker assembly and tightened the head bolts? If cam and pistons were out of sync you may have bent a valve.
Did you align your timing chain with the marks on the cam and crank sprockets?
Old Nov 9, 2009 | 08:06 PM
davo247d's Avatar
ya i alighned everthing up and all that jazz and the psiton will come up and give it enough force to un-compress the valve spring (with valve cover off and manualy cranking the engine) or i could take an extension and tap it on the spring and it would also decompress, ive been told by my fasha to use some carb spray on it and crank it by hand then spay it and repeat a few times but i still dont know
Old Nov 9, 2009 | 08:18 PM
Matt90V6SR5's Avatar
Your fasha...I guess thats gold member for father.
Old Nov 9, 2009 | 08:19 PM
davo247d's Avatar
^correct haha
Old Nov 10, 2009 | 08:41 PM
limon32's Avatar
Like I said above, you have some sort of mechanical interference problem. Tear that head off and replace your valve(s). Maybe even valve guides and seals...
Old Nov 10, 2009 | 08:54 PM
peow130's Avatar
That's kind of what i'm thinking too...
i'd inspect your pistons, too.
Old Nov 11, 2009 | 04:34 AM
davo247d's Avatar
un fortunatly thats what i miight have to do but ive got another head and ill rebuild that one and throw it on i guess
Old Nov 11, 2009 | 08:56 PM
rangerruck's Avatar
I was gonna say; even though I am no mech, and though I totally love the Seafoam treatment trick; I don't think this is going to help you here!!
Old Nov 11, 2009 | 09:21 PM
Mr seafoam spreading the love,or not.
Old Nov 12, 2009 | 08:44 AM
davo247d's Avatar
it didnt so i think im gonna have to pull the head off again
Old Nov 12, 2009 | 09:05 PM
limon32's Avatar
For what most shops charge, its well worth having a machine shop inspect a block or head(s) any time you pull them. They have the right tools and tons more experience than most do-it-yourself mechanics (including me) can hope to.
Once you find a good shop they are worth their weight in gold!
They do a much better job of cleaning them for cheap too!
Old Nov 13, 2009 | 06:32 AM
davo247d's Avatar
ya lol im just really short on money but ill have the head probibly all done today
Old Nov 21, 2009 | 08:15 PM
davo247d's Avatar
so i got the head pulled and stuff well thepiston has a small dent in it =( but idk
here is the bad valve can you see whats wrong?
Here is a good valve for a hint
The stem seal isnt where its suppose to be
Can you see which is the bad valve (the right one)
and its kinda hard to see but there is a small dent in the top of the piston from the exsuast valve (spelling i know)
so what do ya all think?
Old Nov 21, 2009 | 09:16 PM
limon32's Avatar
I'd talk with a decent machine shop, but I can't imagine that little dent being a problem, curious to see what others think...
