ISR too hot!
Old Sep 17, 2010 | 06:46 PM
mtnwkr's Avatar
ISR too hot!
So, I did the ISR mod today. Used 3" exhaust pipe with a 45* bend. It all went together pretty smoothly. I drove around for a bit and then checked the pipe. Boy was that puppy hot! I let it sit for almost an hour and checked again, still hot! very hot actually.. this thing is holding the heat in.
I don't want to have to spend more money now on header wrap. I was wondering If the PVC ISR will be much cooler? Thanks!
Old Sep 17, 2010 | 06:52 PM
MaK92-4RnR's Avatar
every metal surface in your engine compartment gets hot... being that its right above your manifold. ( heat rises )
Old Sep 17, 2010 | 06:53 PM
thook's Avatar
The heat you're experiencing is radiant from the engine. The plastic will not absorb or retain it so much. It cools faster and does not conduct like metal. And, best of all, it's freakin' cheap.
Old Sep 17, 2010 | 06:55 PM
mtnwkr's Avatar
Wow, thanks for the quick replies.
Old Sep 17, 2010 | 06:58 PM
thook's Avatar
Yes, indeed.....
Old Sep 17, 2010 | 07:25 PM
iamsuperbleeder's Avatar
thus why it's called the "intake silencer remover" mod, not a "cold air intake"
Old Sep 17, 2010 | 07:31 PM
mtnwkr's Avatar
yeah, but i don't like the idea of it getting hotter air than it did before. just wondering if i should switch to ABS instead of the steel..
Old Sep 17, 2010 | 09:24 PM
aa1911's Avatar
yes, PVC pipe is MUCH cooler than any metal pipe; if you want an easy fix, use some thermal wrapping. Header wrap is $50-$70 depending on where you go (expensive) but some hot water heater insulation and some aluminum tape and I did a fair job of lowering intake temps; if you have metal it will retain LOTS of heat, my thin chrome intake stayed hot as crap for well over an hour! Exhaust pipe will be really hot too, insulate!!!
At least we're on the subject of "cold air intakes"... they are really "less restrictive hot air intakes"......
Don't feel bad, there's lots of folks in this world who don't know better!
Old Sep 17, 2010 | 09:28 PM
mtnwkr's Avatar
Thanks aa1911, that's what I was looking for. Guess I'll pick up some pvc tomorrow. Should be easy as I already have everything else I need.
I never mentioned anything about a CAI, I know the difference. Just didn't like how the new intake was going to deliver the air much warmer than stock. I don't see how that could be a good thing! The PVC sounds like the ticket.
Old Sep 17, 2010 | 09:37 PM
thook's Avatar
It's not a good thing. The airflow meter....or more specifically......the air intake temp sensor doesn't need to get unduly warm. The engine will run hotter and leaner than it really needs to.
Old Sep 17, 2010 | 09:39 PM
aa1911's Avatar
It is good stuff and will be much cooler; I used 'electrical' pipe on my 4runner and it is fantastic, stays nice and cool. Any plastic intake material that folks are using will be much cooler than any metal piping. (hence the stock intake material for example....)
Old Sep 18, 2010 | 12:06 PM
mtnwkr's Avatar
Re built my ISR with some 3" grey conduit from home depot and some 3"x3" hose clamps. I didn't like the huge 3"x2" connectors. I cut the ends off the old intake to use as spacers where the ISR connects to the TB and VAFM to make the 3x3" clamps work. I think it looks better too.
It's a b1tch to get my dipstick out now, good thing it barely uses any oil.
Old Sep 19, 2010 | 05:54 PM
Fishaa's Avatar
No one has had any problems with the plastic option melting or anything like that have they? That would be my only worry with the plastic.
Old Sep 22, 2010 | 06:36 PM
aa1911's Avatar
no, pvc or any other similar stuff won't melt at all. just makes it a PITA to check the oil
Old Sep 22, 2010 | 06:48 PM
thook's Avatar
True dat!
Schedule 40 is rated for withstanding electrical heat, if that says anything. IOW's it's designed not to retain it. Of course, if you had an electrical short, that would be different.
Old Sep 22, 2010 | 07:21 PM
Originally Posted by thook
True dat!
Schedule is rated for withstanding electrical heat, if that says anything. IOW's it's designed not to retain it. Of course, if you had an electrical short, that would be different.
no but it burns pretty good, even if it does give off toxic gases in the process
but PCV will be fine under the hood there; it doesn't get THAT hot under there...
Old Sep 22, 2010 | 08:15 PM
thook's Avatar
I guess what I meant is.......oh, nevermind.....haha! READ peoples. It's all been discussed already, anyways.
Old Sep 26, 2010 | 09:50 AM
thook's Avatar
Schedule 40 is more than adequate, though. Just sayin'......
BTW, I've sent you an email. Check your inbox sometime.
Old Sep 26, 2010 | 10:21 AM
paynemw's Avatar
subscribed
Old Sep 28, 2010 | 07:37 AM
ET's Avatar
ET
i got the flexible spectre intake hose from autozone for $20 it wasn't too hard to rig up and it can stretch and flex. all i have to do is pull on it in any direction and i can check oil pretty easy.
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
Boomer8404
Sep 10, 2015 09:01 AM
