A/T shifts hard until warm
Old Sep 23, 2010 | 03:49 PM
queso's Avatar
I know this question has been asked many times here, but there never seems to be a good solid answer.
1994 4runner- The automatic transmission shifts hard until it is warm, circa 3 minutes. Each shift feels like a kick in the pants and will snap your neck pretty hard. Once the transmission is warm it plays nice. Fluid is good, I replaced it and the filter ~400 miles ago, long after the problem started.
Old Threads:
https://www.yotatech.com/forums/f116...omatic-212061/
https://www.yotatech.com/forums/f116...n-cold-131482/
https://www.yotatech.com/forums/f116...-a340h-196799/
https://www.yotatech.com/forums/f116...g-auto-151022/
https://www.yotatech.com/forums/f116...-thing-137407/
https://www.yotatech.com/forums/f116...-shift-161297/
Old Sep 23, 2010 | 11:23 PM
myyota's Avatar
I read through some of the links you posted and found a couple of things you should check. 1) make sure the TPS is properly adjusted. 2) There is a shift cable that goes from the transmission to the throttle body, make sure its not sticking or broken and make sure its properly adjusted. When you changed the trans fluid did you use the correct fluid ?.
Old Sep 24, 2010 | 08:56 AM
queso's Avatar
I did put Dex3 in it when I changed the fluid. We have a lift at work that I can jack my ride up on during my lunch break, I will report back.
Why would the TPS or the shift linkage cause temperature dependent problems?
I am saving this for later:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Sep 24, 2010 | 09:00 AM
yotarob2005's Avatar
The detent cable that runs from the transmission to the throttle body can cause you all sorts of problems if broken or out of adjustment. Ask me how I know.....
Liadrin
Apr 25, 2022 02:54 PM
jetpilot
Aug 15, 2015 06:48 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
