Tranny Problems: 94 4Runner Automatic
Old May 17, 2010 | 11:28 PM
grantj22's Avatar
I just bought a 94 4runner It is 4 wheel drive and automatic and when it is cold and sometimes when it is warm it has trouble shifting and seems like it will redline before it shifts unless I let off the gas then it shifts. Any ideas on how to fix it?
Old May 18, 2010 | 03:51 AM
iselloil's Avatar
it wont shift until its warm
Old May 18, 2010 | 04:36 AM
Team420's Avatar
ya, let the rig warm up to normal opperating temp before driving, and see if that helps. Or does this happen all the time....like even after fully warmed?
Old May 18, 2010 | 04:53 AM
iselloil's Avatar
I changed the filter,fluids and solenoids and it still does the same until its warm.
Old May 18, 2010 | 05:06 AM
grantj22's Avatar
Sometimes it still does it even after its warm
Old May 18, 2010 | 05:14 AM
iselloil's Avatar
Have changed the fluid and filters? The shift solenoids control the shift thru the valve body.If they hang it wont shift right.Go to napap and try a bottle of lube guard.Check out there web page.http://www.lubegard.com/~/C-112/LUBE...uid+Protectant
Old May 18, 2010 | 06:16 AM
Marc's Avatar
I can't help you but THEY ARE SUPPOSED TO SHIFT WHEN COLD.
They won't shift into overdrive until warmed up though.
Old May 18, 2010 | 07:46 AM
rustypigeon's Avatar
Check the TPS. If the Throttle Position Sensor is telling the ECU that the throttle is open more than it actually is, it won't shift right.
Old May 18, 2010 | 08:21 AM
iselloil's Avatar
My 4runner is slow to shift,but your right no overdrive until warm.
mskalmus
May 28, 2017 07:51 AM
shar
Jul 9, 2015 12:38 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
