Cause of 5th gear whine?
Old Sep 12, 2010 | 10:56 AM
the joe's Avatar
What causes that 5th gear whine that is so common in the '95 4Runner?
I am putting in a new engine soon and if I can fix this whine while I'm at it I'd really like to.
Also, how much of a problem is a 5th gear whine? Is the tranny likely to die with this type of thing going on?
Thanks for any info on this problem that you can provide.
joe
PS - I did some searching and didn't find the specific answer to this problem. Just so you know, I DID search.
Old Sep 12, 2010 | 11:03 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
5th gear in 4Runner? 5th gear is going out, more than likely from not getting the oil changed..
ever...
The R trannys are strong...
Prolly cheaper to buy another than fix that one.
Old Sep 12, 2010 | 11:04 AM
DupermanDave's Avatar
I've always had a 5th gear whine in all of my manual transmission vehicles. I just don't worry about it. I had it on my 96 suzuki sidekick with 150k miles and even now on my 89 toyota with 251k miles.
That's one thing you can do... ^^^^^^^^^^^
Just change the oil in it... As long as it doesn't jump out of gear, drive it.
Old Sep 12, 2010 | 12:10 PM
Flash319's Avatar
Input bearing.
Old Sep 12, 2010 | 12:36 PM
jhnlennon's Avatar
Originally Posted by Flash319
Input bearing.
I 2nd that, very common on the yota manual trannys. I have taken apart alota yota manual trannys and have yet to see one with a good input shaft bearing. The whine will just keep getting worse. Also, I bet if you listen close enough, you can hear the noisey bearing in all gears and in nuetral.
Old Sep 12, 2010 | 01:53 PM
needsomecam's Avatar
well if you wanna test tht theory while running push the clutch in and see if the noise goes away
Old Sep 12, 2010 | 01:54 PM
BigBluePile's Avatar
When the wife stays at home the whine seems to go away...weird...
Old Sep 12, 2010 | 02:05 PM
camo31_10.50's Avatar
^^lmfao hahahahahahahahahaa
Old Sep 12, 2010 | 02:06 PM
why can't i make anything caps lock? lol
caps lock on the laptop is on....and while i'm typing...it's BIG letters...but when i post..it's not?
Old Sep 12, 2010 | 02:07 PM
except for the "big" in that particular post........??????
Old Sep 12, 2010 | 04:15 PM
greatskiiiier's Avatar
My caps lock is on right now, but this is a desktop at my school lol
Old Sep 12, 2010 | 06:39 PM
the joe's Avatar
So when I swap the engine, can I rake care of that input bearing?
It doesn't jump out of 5th gear, only 1st (and that doesn't happen often).
If I'm going to go ahead with this engine swap, I need to know that this vehicle will go at least 30k miles before breaking significantly. Thoughts?
joe
Old Sep 12, 2010 | 09:01 PM
MudHippy's Avatar
Yes. You'll need the bearing, some RTV(grey), and you might as well replace the input shaft seal while you're at it. Good luck pulling it without opening the transmission housing though. But, you might be clever enough to figure out how to without. I'm sure could if I had to. I'm a genius though so...
CAPS CHECK....mINe wOrKs FiNe? WierD?
Old Sep 12, 2010 | 09:26 PM
krisrayner's Avatar
Does the noise go away when in 4th gear? Mine is noisy in 3rd and 5th but quite in 4th, which indicates countershaft bearings.
Old Sep 12, 2010 | 10:51 PM
the joe's Avatar
It makes no noise in any gear except 5th. The stick vibrates a little, but it's nice and quiet.
How long do you think I have with this tranny?
joe
Old Sep 12, 2010 | 11:11 PM
pruney81's Avatar
It's hard to say, maybe put some Redline MT90 in it, that could buy you some time.
smthwsn357
May 1, 2024 07:28 AM
themightykhoner
Aug 11, 2015 07:37 PM
JAmdor3
Aug 11, 2015 10:53 AM
norcal98
Aug 10, 2015 06:20 AM
mengquis
Jul 13, 2015 10:39 AM
