HELP with a bolt!
Old Sep 16, 2010 | 03:58 PM
mattaway's Avatar
HELP with a bolt!
The bolts for the alternator bracket backed out on me.
I managed to find a bolt that works for the part of the bracket that's under the distributor and holds the dipstick tube down. But I can't find a bolt that will work for the one that's supposed to be under the tensioner pulley for the power steering, the hole is pretty big, I tried a couple bolts I have in the garage, they're all either too small or too big.
Sorry for my terrible explination, but does anyone know what size the bolt is?
Old Sep 16, 2010 | 04:00 PM
pwd's Avatar
pwd
Not sure what size it is, but I'd recommend getting it from the dealer. You will pay more... but it will fit perfect.
Old Sep 16, 2010 | 04:35 PM
mattaway's Avatar
Good idea, pwd, if noone here knows the size, I'll stop by the dealer after work tomorrow. Tryin' to get her put back together for this weekend.
Old Sep 16, 2010 | 04:57 PM
Solomon8's Avatar
I'd call the dealer ask them what size. Then off to the hardware store.
Old Sep 16, 2010 | 05:01 PM
mattaway's Avatar
Even better idea!
Old Sep 16, 2010 | 05:05 PM
RustBucket's Avatar
If it's a bolt on a big bracket it is probably either an M8x1.25 or an M10x1.25. Get one of each about 20mm long from the hardware store and I bet one will work.
Old Sep 16, 2010 | 05:09 PM
mattaway's Avatar
The one that's under the distributor is an M8x1.25, but the one I need is way bigger, I tried an M10x1.25, and a 3/8 16 and they were both too small. 7/16 14 was the next size up that I had and it's too big!
Old Sep 17, 2010 | 06:33 PM
mattaway's Avatar
I called the dealer and they wanted the VIN, so I had to call back later, and the guy was like "yeah, I can see it in my computer, but we don't stock it and I can't tell what size it is, it should be the same size as the other one" and he argued back and forth with me about how it should be the same size as the other one but it's not... so I hung up..
Turns out it's a m10x1.50 and it needs to be 2 1/2-3" long
Old Sep 17, 2010 | 06:46 PM
thook's Avatar
Call DeathCougar at Nix99. If your area's anything like mine, you'll have a hard time finding that bolt. I even have a hard time finding them at specialty fastener shops. They seem to be mostly geared towards construction and industry. But, never hurts to call them if you have any near you.
Old Sep 17, 2010 | 06:52 PM
mattaway's Avatar
I found one at Home Depot, it's just a regular grade 5 zinc plated bolt, but it'll work. I backed it with a lock washer so hopefully it won't back out again.
Old Sep 17, 2010 | 06:56 PM
thook's Avatar
Son of gun! They have crap for metric choices here. Consider some loctite, eh.
Old Sep 17, 2010 | 07:01 PM
mattaway's Avatar
I put a drop on the first 2-3 threads, didn't want to get crazy with it.
Old Sep 17, 2010 | 07:06 PM
thook's Avatar
Oh, you should be good to go, then. So, get crazy with something else! A purple mohawk maybe.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
