Shocks question
Old Sep 18, 2010 | 04:38 PM
Shootre's Avatar
Shocks question
is it possible to put Pro comp ES9000 Shocks (rear) on a 94 4runner?
cause the dude who is installing mine says it isnt...?
but i'm confused
these shocks
http://www.wabfab.org/IFS-Lift-Kits/...ypage.tpl.html
i got from webfab under 1979-95 toyota 4runner/pickup?
shoudn't they work?
they have a loop instead of a stud
Old Sep 18, 2010 | 10:22 PM
Shootre's Avatar
actually my back shocks have studs
so what do i do now....
Old Sep 19, 2010 | 01:02 AM
bobuk's Avatar
If you have coil rear suspension you will have a stud at the top. Here's all the procomp applications. I have procomp ES9000's on my 93 and 95 models.
Old Sep 19, 2010 | 11:47 AM
Shootre's Avatar
then where can i buy from that has stud suspension for my back then?
cause of bought mine from :wabbit2:
Old Sep 19, 2010 | 11:58 AM
dropzone's Avatar
Fossilized
sounds like you ordered the wrong one.
Just contact Wab-Fab, I am sure he will do what he can to correct it.
Old Sep 19, 2010 | 01:25 PM
bobuk's Avatar
Hi,
Got your pm.
I bought mine from Summit Racing. The link is for standard shocks but they also stock the +4" ones if you're doing a lift.
Bob.
Old Sep 19, 2010 | 01:32 PM
bobuk's Avatar
His website lists the same shocks for the pickup and 4runner right through to 95, but the 4runner changed from leaf rears to coils around 1990.
Old Sep 19, 2010 | 01:35 PM
camo31_10.50's Avatar
instead of starting a new thread...i'll just post here cuz my question has to do with shocks on a 2nd gen 4runner.
i'm sure the shocks on my 4runner will need to be replaced sometime within the next few months.
it has a 4" trailmaster lift up front and trailmaster 4" lift coils in the rear.
no markings on the shocks other than some numbers..gonna run em in a bit and see what kind of shocks i have...they're silver with black boots?..reminds me of bilsteins.
i thought about the Adjustable rancho's...but i'm not much of a hardcore wheeler..and don't see how adjustables would help me.
would like to keep price as low as possible..but if a certain shock is A LOT better than another, and costs a little bit more..then so be it i want the BEST bang for the buck!
also probably going to go with a 2" lifted LC80 coils i believe..or maybe a 1" lifted set of coils...as my 4" coils are sagging.
Old Sep 19, 2010 | 01:36 PM
he means Contact Wabbit...as in CALL him. alot better to talk to someone..than deal with a computer.
especially someone as knowledgeable as wabbit
Old Sep 19, 2010 | 01:45 PM
bobuk's Avatar
Shocks.
I've got the Trailmaster lift on one of my trucks and it is +4" at the front and +3" coils in the rear as standard. Maybe why you think the back is sagging. Fitting +2 coils will make it worse not better, and fitting +1" coils will make it even worse.
Cheers,
Bob.
Old Sep 19, 2010 | 01:50 PM
Landcruiser coils are (stock) about as long as my +3" trailmaster coils right now.
therefore a +2" LANDCRUISER (LC80) coil will be about 5"-6" of lift. in the rear.
i should have specified...i didn't mean a +2" or +1" 4RUNNER coil...i meant LANDCRUISER coil.
Old Sep 19, 2010 | 01:54 PM
thanks for the link to the shocks!!!!!! but why is there 4 different lengths?
i think i'd like to have the long ones for my rear(24" extended length)..and the 18"extended length ones for the front....correct? no? what? more info...never bought shocks for anything except stock vehicles.
Old Sep 19, 2010 | 01:58 PM
bobuk's Avatar
My bad - over here people refer to landcruiser coils as +3" coils hence my confusion.
Fitting anything more than +3" over stock 4runner coils will require the proper drop brackets on the upper and lower links to stop the upper offside arm hitting the gas tank.
Old Sep 19, 2010 | 02:04 PM
that i did not know...i'll look into that..thanks!
Old Sep 19, 2010 | 02:06 PM
bobuk's Avatar
There's only 2 heights - standard or +4".
If you have lifted coils at the rear and bj spacers in the front then consider the +4's (personally I'd fit standard in the front unless you have a bracket lift)
If you're running stock coils etc then buy the standard height.
Old Sep 19, 2010 | 02:18 PM
it doesn't specify standard height...or 4" lifted height.
it just gives the compressed length, and the extended length.
Old Sep 19, 2010 | 02:27 PM
bobuk's Avatar
Look at post #3 - it's from the procomp catalogue and gives the part numbers you need.
Old Sep 19, 2010 | 02:30 PM
part numbers the same from Pro-Comp to Trail-Master?
Old Sep 19, 2010 | 02:32 PM
BAH...i apologize....didn't see the option of 4.000" lifted on the left.........
Old Sep 19, 2010 | 02:37 PM
bobuk's Avatar
No it's me being stupid - This gives the trailmaster applications...
Cheers,
Bob.
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 05:23 PM
SMOD
Jul 27, 2015 01:45 PM
Massmayhem247
Jul 18, 2015 05:46 AM
akaphilly
Jul 9, 2015 02:34 PM
