Shifters Rubbing?
Old Sep 22, 2010 | 08:35 PM
Rob2thec's Avatar
Shifters Rubbing?
So after putting together my shifter assembly today (i did not take it apart) I noticed once everything was together that when the 4x4 stick is in 2H that when going into revers the 5 speed shifter rubs? Its almost like it does not want to even let it go into reverse?
Has anyone else had this issue? I am sure its a simple mistake on my side and it is the first time I have ever put these things back together. But I thought it would go much smoother?
Thanks!!!
Old Sep 22, 2010 | 09:39 PM
SpecialScottie's Avatar
I pulled my t case shifter out and just bent it a little in a vice with a pipe over it
Old Sep 22, 2010 | 11:21 PM
myyota's Avatar
Thanks!!!
It sounds like the t-case shifter is in backwards, take it out turn it around and put it back in and it shouldn`t rub any more.
Old Sep 23, 2010 | 12:28 AM
TNRabbit's Avatar
NAILED it...
Old Sep 23, 2010 | 08:55 AM
Rob2thec's Avatar
Thank you guys for your info. I will try that when I get the truck back from the shop. HAd to send it in to see why the truck will not start.
That is a whole other thread...
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
irv
Sep 22, 2015 11:51 AM
briholt
Sep 20, 2015 10:26 PM
