question on a 91 4runner
Old Sep 20, 2010 | 11:08 PM
sis004runner's Avatar
v6 4x4 5spd. i bought this 4runner and the guy i bought it off of re did the heads and gaskets. theres a tad of water getting into the oil. now he tells me the problem is the round part on the left side on the engine block he calls it there oil cooler thats getting water. the coolant suppose to cool down the oil. ok soits a round thing with a bolt in the middle. anyone know the name or heard of this problem? thanks
Old Sep 21, 2010 | 08:14 AM
thook's Avatar
It's called the oil cooler. But, sometimes it's called that round thing with a bolt in the middle.
Old Sep 21, 2010 | 08:29 AM
thook's Avatar
Possible solution........
Originally Posted by sb5walker
Just a reminder to folks that there are o-rings and a gasket in the cooler that are needed to keep the coolant separate from the oil. This is a place where a worn seal will allow pressurized coolant to get into the oil, so it's important to replace these seals periodically.
Old Sep 21, 2010 | 07:27 PM
how can i get the gaskets for the oil cooler?
Old Sep 24, 2010 | 07:47 PM
i bought the gaskets for the oil cooler and just have it replaced for the heck of it. but right now its in the shop there gonna put the timing belt back on and run a compression test. hopefully it's good cause the guy i bought it from just had the heads re done and still was getting water in the oil. some im hopeing its the oil cooler seals.
Old Sep 25, 2010 | 11:27 AM
camo31_10.50's Avatar
did you take the oil cooler apart??
Old Sep 25, 2010 | 07:25 PM
no right now i have it at my mechanics shop he hasnt looked at it yet he's been busy. so hes gonna put the timing belt back on and do a compression test. but just for the heck of it i will have him replace those gaskets on the oil filter.
Old Sep 25, 2010 | 07:27 PM
heres some pics of it
Old Oct 7, 2010 | 03:24 PM
air getting into the water.
update
ok so i got it back after putting it together then the new radiator blew it started leaking so i got a new one. but my mechanic told me there was air getting into the water. he told me it could be the intake, heads not torqed right, bad head gasket or cracked head.
Old Oct 7, 2010 | 05:15 PM
has anyone ever heard of this brand head gasket set? im so tight on money right now.
Old Oct 9, 2010 | 07:49 PM
ok now i took it to a second shop and they pointed out to me that some of the bolts wernt on the intake. the shop is gonna get some bolts for it in the junk yard for me and im hopeing the ones that are missing arent stripped on the intake.
Old Oct 9, 2010 | 08:03 PM
Joshua4507's Avatar
the 3.0 v6 is prone to head/head gasket issues.
Old Oct 9, 2010 | 08:47 PM
yup the heads just got done too before i bought it less than 200 miles on the rebuilt heads. the guy still thought water was getting into the water. but i heard you have to change the oil a few times after doing a head job to get most of the water out. so he ripped the intake back off and just left it like that so i bought it had it put back together since the heads held compression still but when i had the intake put back on they didnt put all the bolts back in im alittle ticked since a second opinion shop pointed it out to me. the first mechanic told me there was air getting into the heads turns out he didnt put every bolt back in for the intake.
mdev126
Oct 4, 2015 04:48 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
87turboPA
Jul 12, 2015 07:49 AM
Cplmike
Jul 8, 2015 08:47 PM
