steering gear woes
Old Sep 19, 2010 | 07:33 AM
OL' YELLA's Avatar
steering gear woes
i have a 88 pickup that has been leaking power steering fluid from the steering gear box so i am going to start a swap from a 86 parts truck is their any thing i should know before i start the swap so as not to mess anything up like steering wheel position does it need to be locked in place or any thing .any advice would be great thanks
Old Sep 19, 2010 | 08:03 AM
xxxtreme22r's Avatar
yeah your probably gonna need a really good puller if you are not swapping the pitman arm as well.
Old Sep 19, 2010 | 09:44 AM
OL' YELLA's Avatar
im swaping the pitman arm and the box as one unit
Old Sep 19, 2010 | 11:26 AM
sethb's Avatar
I literally just did this a couple weeks ago. I blew out the seals on the gear when I was out wheeling in Ocotillo Wells. 1) swapping with the pitman is the best way to go but you're still gunna need a pickle fork. 2) make sure your steering wheel is locked dead center. 3) keep a close eye on that cotter pin on the pitman arm or you'll have a heck of a time finding the thing. 4) make sure you have some new power steering fluid on hand. I forgot about that initially and had to run to autozone in the middle of everything. 5) pneumatic tools make it a whole lot easier. You can try with regular wrenches but you'll probably end up busting a knuckle. oh yeah, also make sure you've got some line wrenches, you don't want to strip any of the lines on the gearbox.
That's about all I can think of. It's super simple. Good luck and happy wrenching!
Old Sep 19, 2010 | 01:53 PM
myyota's Avatar
Just remember that our trucks use transmission fluid in the power steering system. DO NOT use power steering fluid it will cause the power steering to start leaking.
Old Sep 19, 2010 | 01:57 PM
camo31_10.50's Avatar
good point there MyYota!!!! (even says so on the power steering reservoir i believe..)
cotter pins are easy to find if you break yours or lose them.
pneumatic tools always make EVERYTHING easier
Old Sep 19, 2010 | 02:09 PM
sethb's Avatar
Don't quote me on this, but I swear the lid on my reservoir says DOT3... or maybe I'm imagining it because I really hate being wrong... If that's the case, well then... looks like I've got a power steering flush in my near future... Guess that's what I get for a lack of attention to detail...
Old Sep 19, 2010 | 02:25 PM
myyota's Avatar
No, your truck uses ATF DEXRON ll, that`s what the FSM says.
Old Sep 19, 2010 | 02:34 PM
sethb's Avatar
Well, looks like I've got some work to do when I get off duty tomorrow. I should probably download that FSM. Guess you learn something new every day.
Old Nov 25, 2010 | 10:43 PM
yotaconvert's Avatar
About the power steering fluid
My dad has a 94 tercel for his puddle jumper and his power-steering even says dex 3 transmission fluid only just wish i knew that about my 4runner before i topped off all my fluids when i got it
Old Jan 31, 2011 | 03:55 PM
cr@ves4wheelin's Avatar
Nevermind, just been doing stupid things like refilling power steering pump with not ATF. Probably why my steering box leaks a little bit...
Scotto6591
Sep 1, 2015 03:24 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
