Trying to put a `94 A340H into a `90: how do I convert the speedometer?
Old 09-19-2010, 06:48 PM
4RunnerGuyDotCom's Avatar
Hi guys, (and gals,)
I have spent several hours searching for some answers in the hopes that I wouldn't have to start a new thread. So, my apologies in advance if the answers are already here...
Here's my issue. I have a 1990 4Runner with the 3.0 V6 and the A340H automatic transmission. The tranny is slipping pretty bad in reverse and 1st. I have a good tranny out of a `94 4Runner, and I hope to do a simple swap. But I know I am going to run into at least one issue; the `94 trans has the electronic speedometer, while the `90 is mechanical.
I am worried that there may be other incompatibilities, but I am already aware that the speed sensing is different. I could use your help... what do I need to do to put the `94 tranny in the `90?
Thanks!!
Morgan
Old 09-19-2010, 07:23 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
damn, wrong way... delete
Have you tried taking the speed sensor out of the 94 and seeing if it looked the same as the end of the speedo cable on your 90?
Old 09-19-2010, 07:59 PM
Well, you had to go and put an excellent and obvious solution out there for me...
The tranny is in storage an hour away, but unless someone knows for sure what the procedure is for this swap, then that is clearly the best answer; just look.
Any idea if there's any other compatibility issues to be on the lookout for? Different electrical plugs, etc.?
Thanks!! I appreciate it.
Old 09-19-2010, 08:20 PM
I find it hard to believe that Toyota would change a casting for a different cable, or type of speed sensor...
According to Marlin, this is the electro unit. http://www.marlincrawler.com/transfe...eed-sensor-oem
And this is a pic I got off the internets...
https://www.yotatech.com/forums/f116...22/index3.html
Old 09-20-2010, 03:13 PM
YOU ROCK!! Everything looks good. Thanks for the help man!
09-04-2015 09:27 AM
TammyMarie
07-15-2015 11:14 AM
crashburnoveride
07-10-2015 06:39 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Trying to put a `94 A340H into a `90: how do I convert the speedometer?
