22re electrical nightmare
Old Sep 16, 2010 | 06:53 PM
old4runner's Avatar
I pulled my motor (89 22re), put a new clutch in, replaced all of the gaskets & seals and put it back in and now my truck has these symptoms:
When I crank the motor it will rotate once or twice and then the starter will spark. When cranking the motor the ground strap on the drivers side gets hot, I suspect that this one might not be a ground strap at all as it is an insulated wire so I think I have it connected incorrectly, it comes out of the same group of wires that connects to the alternator. When I pulled the distributor out and put it back in the coil and the distributor sparked.
Old Sep 16, 2010 | 07:08 PM
HighLux's Avatar
Check the factory service manual for the wiring...do a search for factory service manual. Should be easy for ya ta figure out.
Ok...the broken off fingernail in your avatar hurts to look at...ouch@$%#^!
Old Sep 16, 2010 | 07:42 PM
Ron Helmuth's Avatar
keep a fire extinguisher handy so you won't need it. Not trying to be a smart aleck. But clearly things are not connected correctly, anything could happen.
Old Sep 16, 2010 | 10:32 PM
thook's Avatar
Oh boy........a s'thparkly can o' worms!
Need pics of what's going on, if you can swing it.
Old Sep 16, 2010 | 11:20 PM
wyoming9's Avatar
Red face
Sounds like you might have some loose connections.
Your ground cables are not giving you a good ground so all current is trying to find a ground.
A few wires hooked up wrong also??
The Toyota electrical manual for your vehicle just makes wiring problems so very easy to troubleshoot
Old Sep 19, 2010 | 04:25 PM
skypilot's Avatar
The ground cable is a big black one and goes into the block with a 12mm bolt. Goes directly to the battery, along with the positive cable going to the large lug on the starter.
Better be safe and keep a garden hose handy too.
You may also have some blown fuses too.
Old Sep 21, 2010 | 06:45 AM
old4runner's Avatar
I had a loose ground strap and a loose connection at the starter, once I tightened them up the symptoms all went away.
coryc85
Sep 9, 2015 06:24 AM
redneck17
Aug 5, 2015 10:03 AM
Mrhoadley
Aug 4, 2015 06:08 PM
v_man
Jul 23, 2015 04:01 PM
AaronM
Jul 8, 2015 07:15 PM
